Thread: pulley swap question
Results 1 to 15 of 15
  1. #1 pulley swap question
    SE Level Member jersey jok3r's Avatar
    Northern New Jersey
    I recently started to mod my gtp with the advice of many of the people on this website. The car has a k and n intake, zzp wires auto lite 104s iridium, 3' dp with high flow cat. U bend delete, borla cat back and a 180 t stat. I actually bought a 3.4 pulley with all these parts but did not install due to a lot of bad feedbak. I am also going to order a tuned pcm in the next couple of weeks, with the mods I have along with the pcm which size pulley could I upgrade too to make more power but not destroy my engine?
  2. #2 Re: pulley swap question
    in a house
    Quote Originally Posted by jersey jok3r View Post
    You still need to do something with that front manifold. Either Plog or better yet headers.
  3. #3 Re: pulley swap question
    Wausau, WI
    I wouldn't go beyond 3.4 w/out an intercooler or rockers............just my opinion though. It's your motor......... Depends on if you are getting a mail order tune or a custom tune as well. You will need to get rid of the front exhaust manifold as it will cause KR..get a PLOG or if you want to continue modding beyond the 3.4 setup(which apparently you are) just get headers.........
  4. #4 Re: pulley swap question
    Wausau, WI
    Quote Originally Posted by silverstreak View Post
    sure you beat me to it...........
  5. #5 Re: pulley swap question
    Northern New Jersey
    I'm not going any further than a 3.4 I was going to do a mail order pcm from overkill but I found a tuning place not that far from me but I heard the tunes are very expensive so I'm not really sure what I'm going to do about that, I just want to find a safe pulley size. Is the manifold a ***** to do or no?
  6. #6 Re: pulley swap question
    Charles City, IA
    Doing the powerlog is very easy. You can knock it out in less than an hour. Get that on and get a scanner and see where you sit. Then get a pcm. Scan again and see where you sit for kr. Then you probably could go 3.5" or 3.4".
    SMGPFC Two Nipple General
  7. #7 Re: pulley swap question
    Moore, Oklahoma
    Get a scanner... you obviously don't know what kinda KR your car is getting. Do the PCM and then buy a scanner and see how the car is running and report back. If you have 0 KR , you're ready to step smaller. You may need to go colder plugs and tweaks it a bit even with adding a 3.4.
    Scan it, thats all I can say. But I don't know anything at all...
    Shawn W. Larsen
  8. #8 Re: pulley swap question
    Quote Originally Posted by Liquifire View Post
    You don't need a Intercooler to safely run a 3.4" pulley...and rockers...rockers would cause more KR IMO because they let the car breathe more, thus needing more exhaust work.
    If they don't have any knowledge or experience tuning the 3800 platform then don't go to them. Get a DHP 1.0 PCM (3800 Performance). Best mail order tune out there...DHP's are the best and have always been the best. Proved that when I couldn't break 14.2 with a ZZP PCM and ran a 13.8 with my DHP. And the manifold is easy...just get some PB Blaster and let it sit on there for awhile so your don't rape your hands breaking the exhaust bolts.
    Quote Originally Posted by Iron Indian View Post
    NANANANANA Vanilla face...your right...you know nothing
    LOL
  9. #9 Re: pulley swap question
    SE Level Member Robotech's Avatar
    California
    Definately go with a DHP PCM if you can get one. For the level of modding you're wanting to do they are perfect and well tested by the community.
    Front manifold is very easy to get off IF you have the proper tools. I believe they are 1/2" (13mm) in size. Be sure to have a open end wrench and a good fitting socket to get to them. I'd also be sure to have some extensions and a swivel as these will make removing them even easier. As was mentioned above...a little PB Blaster will make your life easier too.
  10. #10 Re: pulley swap question
    Northern New Jersey
    I appreciate all your help guys
  11. #11 Re: pulley swap question
    Jersey
    No one mentioned it, so i will. Get new exhaust manifold bolts. When I did my plog I had an old rusty one break on me when i was tightening down, leaving a broken bolt in my cylinder head :/
    16' wrx sti- stock
  12. #12 Re: pulley swap question
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Well looks like everything was already covered. Oh well. But with that combo of parts u will be pretty happy. That's what I've got and it works great. Let us know what happens
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  13. #13 Re: pulley swap question
    Aug 2008
    Long Island, New York
    dude i you are from jersey go to Tune Time Performance in tom's river to get tuned... dont waste your money on those shelf tunes. trust me you will be happy
  14. #14 Re: pulley swap question
    Wausau, WI
    I said if he planned on going beyond the 3.4 he should get these along with the exhaust mods. If staying on 3.4 he should get the exhaust mods first and then the rockers and/or intercooler if you want at that point(big step in money right here)
  15. #15 Re: pulley swap question
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    please get a custom tune. dont ruin the true potential of your mods with an off the shelf tune. ive had both and trust me a custom tune is at last twice as good as a shelf tune.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  1. Supercharger Pulley Swap [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 12-04-2011, 03:16 AM
  2. Pulley swap question ------>>> NEW GUY
    By mjm06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 01:00 AM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. another top swap question
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 12:59 PM
