Thread: Types of Mods for the 3.8
Results 1 to 15 of 15
  1. #1 Types of Mods for the 3.8
    SE Level Member impala04ss's Avatar
    boston
    I got the 04 Impala SS. I put in a smaller pulley a 3.4, autolites 104 plugs, throttle body spacer, k&n intake, exhaust. What other mods you think will be effective. I recently looked into reprogramming my pcm...I am a little sketched out if I need to reprogram my security system...tell me what you guys think of mods and so forth =)
  2. #2 Re: Types of Mods for the 3.8
    Charles City, IA
    Take that pulley off you do not have the supporting mods for it. You should really look into a custom tune. What do you mean by exhaust?
    SMGPFC Two Nipple General
  3. #3 Re: Types of Mods for the 3.8
    Probably a catback. Read the threads on here about pulley drops and realize that your destroying your car.
  4. #4 Re: Types of Mods for the 3.8
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    You don't have to take that pulley off...
    BUT - don't flog the car either. The point is you need to invest in exhaust modifications - SOON - or you are running a risk of this happening:
    On the list of performance modifications - a pulley drop is about #6, to be honest - when talking about a bone stock car.
    You need to get (in no certain order):
    1) An exhaust manifold upgrade - either PLog, headers, something
    2) A catless - or hi-flow catted downpipe - get that U-bend gone ASAP
    3) An improved air intake system - either home-made or complete system purchased - but it needs to be a FWI for best results.
    4) Colder plugs - Autolite 104's or similar
    5) A custom tuned PCM - preferably mated with some form of active, real-time scanning tool.
    6) THEN - when you have done these things, at minimum, and you have A/F ratios dialed in, KR tuned out as much as you can, etc etc - THEN - you can drop a pulley size. The drop to a 3.4 is the most popular - but you have other options - personally, I think the 3.5 is underrated for beginning performance gains - but if you do these things, you can (typically) run a 3.4 without any negative ramifications.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  5. #5 Re: Types of Mods for the 3.8
    boston
    Quote Originally Posted by Swash View Post
    -Swash
    Ill look into getting the u bend removed...does anyone know a good and reliable performance shop in the Boston area that does reprogramming PCMs....?
  6. #6 Re: Types of Mods for the 3.8
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    If u buy either a catless dp or a highflow cat dp it will come with a u-bend delete. Its just a straight pipe. My dp helped a lot. Made it sound deeper too
  7. #7 Re: Types of Mods for the 3.8
    Quote Originally Posted by impala04ss View Post
    Any good exhaust sop can do it and if all fails...buy a U-Bend Delete from ZZP...they are like $40.
  8. #8 Re: Types of Mods for the 3.8
    Jersey
    damn, your list should be this.
    -Headers (asap)
    -aeroforce gauge or scanmasters
    -tune
    16' wrx sti- stock
  9. #9 Re: Types of Mods for the 3.8
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    hp tuners hooray!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  10. #10 Re: Types of Mods for the 3.8
    boston
    Quote Originally Posted by 99prixgt View Post
    -Headers (asap)
    -tune
    Cant tune yet, cant do headers yet. I still got a warranty on my car otherwise if they see it my warranty will be vioded. Luckily they don't notice the pulley drop cause its so minor and only way to tell if you measure it which I doubt they will. I got a couple thousand miles left once its up I'm putting headers and tuning it up!
  11. #11 Re: Types of Mods for the 3.8
    Apr 2009
    ERIE
    hptuners will no show on the dealers scanner. u can use it with a warranty
  12. #12 Re: Types of Mods for the 3.8
    Quote Originally Posted by DOUGLASMELTER View Post
    Depends man...when they scan the PCM and notice changes to it then they are gonna either say something or re-flash it to a stock setting and kill your tune on the car.
  13. #13 Re: Types of Mods for the 3.8
    boston
    Yeah that's what I heard as well. I know Intense PCM, if your pcm gets flashed to stock you can get one more tuned PCM for free....
  14. #14 Re: Types of Mods for the 3.8
    Jul 2008
    sumter,south carolina
    02 GTP with mods 05 GP for DD
  15. #15 Re: Types of Mods for the 3.8
    Apr 2009
    ERIE
    even if they did...if u have hptuners just reload it. takes 30 seconds and i know because it tells u who long it takes. it has a small ego problem as its always bragging lol
  1. New Mods?
    By gucci in forum General Tech Discussion
    Last Post: 01-10-2009, 07:55 PM
  2. Three GPs with T/A mods
    By Injun #4 in forum Visual/Body Modifications
    Last Post: 06-16-2008, 08:41 PM
  3. Mods to Help MPG
    By anks106 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2008, 08:14 PM
  4. A look at different types of spark plugs
    By SyntheticShield in forum General Tech Discussion
    Last Post: 04-10-2008, 11:24 AM
  5. best first mods to do
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2007, 07:50 AM
