Thread: Quick question on 97 gtp
Results 1 to 5 of 5
  1. #1 Quick question on 97 gtp
    Grand Rapids, MI
    I got one, and because of that... ill be around here a lot now!
    While I was reading I ran across someone who had said the 97 gtp's dont handle mods as well as 98-2002... just out of curiosity I was wondering what I shouldnt be doing to this car if I dont want it to blow up.
    I have K&N intake... 3.5in pull w/ quik exchange, headers, 3in downpipe and 3 in full exhaust, and I wuddnt mind doing more stuff but its more important to me that I get a lot of miles out of this car, 130k and counting.
    So any suggestions whatt not to do?
  2. #2 Re: Quick question on 97 gtp
    Wausau, WI
    what you should do is get a tune..............fwiw. I have a 98 and not sure other than the PCM is different from your car to ours and I had heard that 97's have a weaker trans(not sure on this...just what I heard).....someone will pop in and expand on this soon....
  3. #3 Re: Quick question on 97 gtp
    Banned - Busted For Scamming
    Feb 2009
    no this has been discussed before, the 97 gtp has the same tranny.
  4. #4 Re: Quick question on 97 gtp
    GT Level Member BoostedComp's Avatar
    Youngstown
    the 97 gtps have the same tranny as the 98+ its the gt's and se's that have the ****ty vacuume powered tranny
  5. #5 Re: Quick question on 97 gtp
    '97 GT - Crap Transmission
    '97-'02 GTP - 4T65E-HD...all the same...the '03's have the hardened 4th shaft, and stronger valve body (hence why they can't use a '98-'02 PCM)
    Get a tune. And colder plugs.
  1. Quick Question
    By High Rolling GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2009, 01:13 PM
  2. quick question
    Last Post: 06-04-2009, 06:15 PM
  3. Quick Question!!
    By rocafella2032 in forum Tires & Wheels
    Last Post: 05-14-2009, 11:11 PM
  4. Going to 3.4. Quick question.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2009, 01:50 AM
  5. just a quick question
    By FtBll Coach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-21-2009, 10:04 AM
