Thread: AN Fuel Line Setup
Results 1 to 20 of 33
  1. #1 AN Fuel Line Setup
    Oklahoma
    Well with the car out of commission and planning to yank the engine along with the tranny so I can rebuild the tranny and do some engine upgrades, Im wanting to do a complete AN fuel set up. Tank to rails. From the connection to the fuel pump, to the connection at the rails.
    I know they make quick connect/disconnect AN fittings so I can connect to both the pump and rail without modification, what I dont have are all the part numbers and stuff I would need. Well I have a couple, but I want to make a complete list on what I will need so I can order everything and I also need to know what size SS Braided line I need.
    I believe the feed line and return lines are different sizes, arent they? If so, what size fuel line do I need to get.
    Anyway, if you have done a complete set up I would certainly appreciate pictures and part numbers. I havent decided if I will do after market rails yet because the only ones I would consider are PRJ's and they aren't cheap. Id rather do the lines now and save up for the fuel rails later since I could easily do those with everything back in the car.
    I appreciate any and all help.
  2. #2 Re: AN Fuel Line Setup
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    can you post up what numbers you do have?
  3. #3 Re: AN Fuel Line Setup
    Oklahoma
    I thought I had the numbers saved in my PM's but apparently I dont and it will have to wait until I get home to post up what I have.
  4. #4 Re: AN Fuel Line Setup
    SW Chicago Suburbs
  5. #5 Re: AN Fuel Line Setup
    Oklahoma
    Note to self:
    Scratch Toasty off the Christmas card list and revoke his account.
  6. #6 Re: AN Fuel Line Setup
    SW Chicago Suburbs
    Note to self:
  7. #7 Re: AN Fuel Line Setup
    I live here. UR LOSN's Avatar
    Rockford, IL
    Scotty, I will go out to my S10 and snag those numbers and post them up when I get home from work. also for the difference in size...yes the fittings are different size..the fittings make up for it, as you are able to use the same -6 line. I will put together a list for ya tonight...but until then.
    BAN TOASTY!!! MEWAHAHAHAHAHA!!!
  8. #8 Re: AN Fuel Line Setup
    SW Chicago Suburbs
    Quote Originally Posted by UR LOSN View Post
    MEWAHAHAHAHAHA!!!= + ???
    whatev!
    :P
  9. #9 Re: AN Fuel Line Setup
    Moore, Oklahoma
    I want this info too! I want to do this mod this weekend with my car. I plan on using XRP fittings since I can get em local here.
    Shawn W. Larsen
  10. #10 Re: AN Fuel Line Setup
    Oklahoma
    XRP fittings?
  11. #11 Re: AN Fuel Line Setup
    SW Chicago Suburbs
    XRP fittings?
    brand of -an fittings..
    XRP Hoses and Hose Ends
    for example
  12. #12 Re: AN Fuel Line Setup
    Oklahoma
    I do believe I'll have to bookmark that page.
  13. #13 Re: AN Fuel Line Setup
    SW Chicago Suburbs
    there seem to be other places that sell them, too.
    not sure what the $$ difference is between oh say earl's, etc
  14. #14 Re: AN Fuel Line Setup
    Rockford, IL
    ok, sorry for the wait. the quick disconnect fittings to -6AN line are:
    640850, and 640860. sorry, these were made by Russel......this gives you both the 3/8ths, as well as 5/16ths.
    then you will need the female ends that screw onto these fittings. these are entirely up to you...which angle you want.
  15. #15 Re: AN Fuel Line Setup
    Rockford, IL
    I personally like Aeroquip line..this is what I use in all my cars.
    I go through summit, or jegs...as they usually have fittings cheaper...
  16. #16 Re: AN Fuel Line Setup
    Oklahoma
    So those fittings would be the quick connnect/disconnect that would get me connected to the pump and rails, correct? Then it would just be a matter of running the line from from those connectors with female connectors? Am I missing anything?
    What about the fuel filter?
  17. #17 Re: AN Fuel Line Setup
    SW Chicago Suburbs
    who needs a fuel filter??
    at that point, you could likely run an aftermarket type fuel filter setup, using whatever size fitting neccessary...
  18. #18 Re: AN Fuel Line Setup
    Oklahoma
    Well I didnt know if it would be good to continue to use the OEM filter or just use one specifically for an AN set up.
  19. #19 Re: AN Fuel Line Setup
    SW Chicago Suburbs
    eh, i dont think it matters too much, just more of a question of weather or not the AN line size would fit the push on side of the fuel filter.
  20. #20 Re: AN Fuel Line Setup
    Oklahoma
    Im pretty sure it will, but the option is there to use AN threaded type fittings if needed.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. PRJ Gen 3 fuel rails?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2008, 02:42 PM
  3. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
  4. 04+ fuel return line
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 11:40 PM
