Thread: Air Bag Light On
Results 1 to 11 of 11
  1. #1 Air Bag Light On
    Apr 2011
    Gainesville, FL
    97 GTP - Anyone know where the wiring harness runs in the engine bay for the air bag system and where the sensor(s) is? I had to lower my engine cradle to remove a broken bolt in the block and after getting it back together, the air bag light in the dash comes on and won't go off. Thanks
  2. #2 Re: Air Bag Light On
    Apr 2011
    Gainesville, FL
    So, I probably did a dumb thing that messed this up. When I lifted my engine cradle back up initially, the rack and pinion didn't interlock with the steering column, so when I turned the wheel it spun around and around. This would have messed up the air bag components in the column wouldn't it?
  3. #3 Re: Air Bag Light On
    SE Level Member carscomefirst's Avatar
    mo
    Quote Originally Posted by jpearsall187 View Post
    Yes, It will take out the clockspring.
  4. #4 Re: Air Bag Light On
    Apr 2011
    Gainesville, FL
    How do I access that and repair it? Thanks
  5. #5 Re: Air Bag Light On
    Apr 2011
    sudbury
    i have same issue and cant wait to find out the fix....
  6. #6 Re: Air Bag Light On
    mo
    I have never had to replace one yet. Its in the steering column behind the steering wheel I think. I would look at a service manul before doing it.
    If I had to guess I would say:
    Disconnect battery, remove airbag, remove steering wheel. replace clockspring, and put back together.
  7. #7 Re: Air Bag Light On
    Nov 2010
    Atlanta Ga
    Its not bad. Disconnect battery. Remove air bag, then steering wheel. There is a snap ring holding the coil to the column. Make sure wheels are straight as new coil wheel be indexed to the straight ahead position (its indexed to only really fit one way).Make sure the wave washer stays on the column behind the coil when you go back together.
  8. #8 Re: Air Bag Light On
    Apr 2011
    sudbury
    how much do those sensors go for...?
  9. #9 Re: Air Bag Light On
    Nov 2010
    Atlanta Ga
    They can be expensive,I would look for a used one.
  10. #10 Re: Air Bag Light On
    Mercer, Pa
    Do you have radio controls in the steering wheel? Do they still work? If radio controls work it may be front chrash sensor mounted on the front bumper that you should check.
  11. #11 Re: Air Bag Light On
    Apr 2011
    sudbury
    no radio controls...standard steering and when i had my bumper off... i dint see any sensors..
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  3. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
