my gtp is running about 210 degrees should be running alot cooler had to disconnect the yellow wire on the temp sensor to make the fans run all the time because they only turned on low when the car got real hot just fixed intake gaskets and have 180 degree stat and still runs at 210 any one else have this problem its driving me nuts
