I need to take the whole ash tray draw out and I can't figure out how to, I don't want to yank too hard and break it, anybody know?
no idea i havent messed with the tray but yeah sometimes force is the only way =] i still have the OEM piece of paper in my ashtray haha
Remove the dash bezel, the large main piece of trim that surrounds the gauge display, radio, HVAC etc.
Once that is removed there is screw that hold the ash try to the dash frame/structure. I believe there is only two, maybe 4. Should be right on the front of it, remove those, and it will pull right on out. You will have a light wire to disconnect as well, just disconnect, and hang it on up in the dash out of the way.
I don't smoke, and find the ash try useless, so I removed mine, which made the cubby hole below it much larger and more useful. Back when I did this, i also had two gauges mounted down there, which I do not anymore, but its still nice its out of the way.
Hope that helps.
~F~
gr8 you give me a idea to remove mine haha i dont smoke also and the cubby would be nicer if it was opened up =] good idea bro thanks ha.
Thanks Gr8racingfool, Thats a big help. I'm gonna mess with it this weekend. I don't smoke either, I have train horns that were on my last car and i'm just getting around to putting them on the GTP. I got them installed already, I want to put the button under the ashtray draw so it's out of sight, but I have to remove it to drill the hole. these horns are the best for scaring the **** out of people, best $500 spent.
damn thats an expensive horn but im sure it was well worth it. I relocated my head unit to where my ashtray used to be. A touchscreen for my carputer is in the stock HU location
