Ok i need some ideas on this one. Every time i sit at a light or a stop sign or just at idle in the driveway my oil light flickers an the hud says check gauges. The second i touch the throttle the light goes back out. The oil level is fine an it doesnt seem to be loosing oil pressure. The only thing wrong that i can find is the dipstick is broken. The plastic part w/ the o-ring is snapped off the top so i pull it up to the cap an put it in like normal an it stays an seems to seal. Could this be causing my problem?
