Thread: pcm???
Results 1 to 5 of 5
  1. #1 pcm???
    wi
    Will and aftermarket pcm from overkill help my 05 gtp? It's only got a fwi on it so i didn't know if it would be worth the money. Also do these come pre set to your car or can you also adjust it yourself?
  2. #2 Re: pcm???
    GT Level Member DWosik13's Avatar
    Detriot,MI
    It will make a difference on shifts points and so on but most of the aftermarket pcms you buy are locked but if there not locked the only way you can tune them is if you have a tuner
    2002 BLACK GTP ... R.I.P.
    New Car 2009 Cobalt SS
    http://www.cardomain.com/ride/3352208
  3. #3 Re: pcm???
    Donating Users blowfishRus6's Avatar
    g.a.
    overkill is locked. the car will deff run better.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: pcm???
    SE Level Member chili's Avatar
    MN
    Overkill is now UNLOCKED according to his website...version 4 or something. Sounds like the guy does a great job with driveability issues and trans shifting.
    04 CompG, DP, Wizair, 180 t-stat, 18" Verde 5ives, my DD...170,000 and counting!
  5. #5 Re: pcm???
    g.a.
    yep, version 4 is editable with HP tuners.
    thats pretty sweet. i might just get one now.
    its slow.
pcm
