Thread: L67 Vs L36
Results 1 to 8 of 8
  1. #1 L67 Vs L36
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    ok looking at getting a block and i was just wondering what is the difference in the blocks? is the bore different?
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  2. #2 Re: L67 Vs L36
    Oklahoma
    Do you mean L67 vs L32? I think the L36 is the naturally aspirated block and if so Im not sure about that with the compression they have. I could be wrong about that though.
  3. #3 Re: L67 Vs L36
    Hoffman/Schaumburg, IL
    If it is between l67 and L32, l32 pistons are moly-coated, and connecting rods are powder-forged I believe
  4. #4 Re: L67 Vs L36
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    l67/32=8.5:1 iirc
    l36/26=9.4:1 iirc
    that is the only difference. o, and all 05+ and some 04's have powdered metal rods, which are batter then cast, but not as good a forged.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  5. #5 Re: L67 Vs L36
    wamego,KS
    i was just curouis because i think if i could i would just get the L36 block and put all the parts from a L67 in it.
  6. #6 Re: L67 Vs L36
    The blocks are identical, but the L36 has different rods and pistons. The L36 internals are a little lighter. A well prepped L36 can handle 350-400hp.
  7. #7 Re: L67 Vs L36
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Quote Originally Posted by Ron Vogel View Post
    Are the L26 internals stronger ?
    Because my buddy is DDing his L26 Turbo with 400whp on 13psi.... now he's on 16 PSI.....
    Lumpy Gen 3
  8. #8 Re: L67 Vs L36
    Taylor,MI
    Quote Originally Posted by scooz14 View Post
    l67/32=8.5:1 iirc
    l36/26=9.4:1 iirc
    ^^^ His L26 block probably has the powdered metal rods, which would make it stronger than the L36 rods.
l36, l67
