I don't use Hptuners but you should be able to log boost. The stock map sensor limits to you reading only around 14.7psi boost. When tuning, reading boost isn't that helpful, its just nice to know what your at.
Ill be honest, I have no clue what the car will record on hpt on the GTP's. My car was n/a before i supercharged it and it ran a 1bar sensor wich records negative psi.
the two bar system that is stock on the GTP will record boost on hpt. Im fairly sure that the map tables on the GTP's only goest to 5psi though.
I wouldnt worry about logging it anyway, but yea if you want to run standalone items, the EIO version is the way to go. If you just want something to delete codes and scan, then stick with the Standard version. I think without the ability to log a wideband with the standard version, Its basically useless. (IMO)
You can read boost up to 14.7psi on the stock gtp pcm/map. It will read out on a scan guage or an aeroforce guage as I have one. As far as logging it, you may have to make a .pid and convert the map kpa values to boost.
As far as hptuners standard version I thought you could wire in the wideband signal through the egr and create a .pid to be able to log wideband values without having the a/d inputs.
Yea, you can wire it through the EGR, but it doesn't help if you are in a smog state.
