Thread: m90 Rotors
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 m90 Rotors
    Jan 2009
    Long Island
    I'm rebuilding my M90 and I need to have my rotors re coated, anyone knows where i can have this done and what it would cost? Thank You.
  2. #2 Re: m90 Rotors
    if you want a spare set of rotors instead of shipping yours out somewhere i have some that are pretty much junk because one of the rotors had a knick in it and now they bind. good for a core.
  3. #3 Re: m90 Rotors
    Jan 2009
    Long Island
    If i get yours, they might be charging me for rotors too.I don't know how it works.
    Thank you and I'll be keeping you update.
  4. #4 Re: m90 Rotors
    TDCRacing
    Guest
    The rotors can not come apart or seperate. Therfore they can not be coated.
  5. #5 Re: m90 Rotors
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It can be done, but it ain't cheap. This is the only place I know of that does it, but I don't know anyone that's used them.
    The High Speed Lab, Roots-type Supercharger Rebuild Services for All Eaton Superchargers
    2001 Buick Regal LS - Almost Stock
  6. #6 Re: m90 Rotors
    TDCRacing
    Guest
    Jet Hot coats rotors. IT's 100 bucks a peice. That is if they were able to be taken apart.
  7. #7 Re: m90 Rotors
    Jan 2009
    Long Island
    I'll try to take mine apart tonite and shoot some pics.I have everything apart and parts.I just need to do the rotors and powder coat the cone and case. thanks again guys.
  8. #8 Re: m90 Rotors
    Banned - Busted For Scamming
    Feb 2009
    it has been done, but when they put it back together it shredded the rotors b/c they didnt get them clocked right, as they have no splines, just pressed in place. You would have to have pro do it, and its gonna cost like $800 at least. If you need a set i have one that are in good condition, a few spots that can be touched up.
  9. #9 Re: m90 Rotors
    Jan 2009
    Long Island
    Okay, here's the deal HSL said (Wayne-Shop foreman). I spoke with him for like 7mins and he was very honest saying I'll loose like 18HP without the coating. If mine is not making noise or leaking he advised me to just put it back and run it till it makes noise.He can do the rotors for $127 and the gear assembly will have to be rebuild since he's taking it apart. the whole deal is $300 to rebuild and $127 to recoat. Both has to be done together. I will have to ship him the one i have and he'll send me one or he can ship one for me and send the core back.
    The only thing that bothers me is the alignment. I need a bad set to take apart and I don't want to dissassemble mine (because it can still be use) and then can't get it togther right.
  10. #10 Re: m90 Rotors
    Feb 2009
    its gonna require a 60 ton press and some ingenuity to make a holder so you dont break the case.
  11. #11 Re: m90 Rotors
    Barksdale AFB, LA
    Just buy a used rotor pack. Not worth that much money. Hell I think you can get a new rotor pack for that money.
    2009 Subaru Impreza WRX STI
  12. #12 Re: m90 Rotors
    Quote Originally Posted by Sabrewings View Post
    this guy knows whats up. also, pm'd you back.
  13. #13 Re: m90 Rotors
    Jan 2009
    Long Island
    I did what i promised this evening and it was completely disassembled.The hardest thing was to find the right seal to replace what i took out.So I'll be looking for those seals!
  14. #14 Re: m90 Rotors
    Feb 2009
    so did you disassemble the rotor pack or just the supercharger itself?
  15. #15 Re: m90 Rotors
    Jan 2009
    Long Island
    "so did you disassemble the rotor pack"
    Two bearings behind the gears and then two double lip seals.
    "1" plate housing is being washed in ultra sonic washer right now.I'll get it tomorrow evening.
  16. #16 Re: m90 Rotors
    QCA, IA
    I've heard those seals are nearly impossible to find, you have a source?
  17. #17 Re: m90 Rotors
    Jan 2009
    Long Island
    Quote Originally Posted by Scimmia View Post
    So it seems, no source as yet!
  18. #18 Re: m90 Rotors
    QCA, IA
    grrr, I think I remember seeing some of them for sale somewhere a while back, but for the life of me, I can't figure out where it was! If I can remember, I'll let you know.
    I'm not sure they were sold separately, though.
  19. #19 Re: m90 Rotors
    Jan 2009
    Long Island
    I will need help locating these, thank you!
  20. #20 Re: m90 Rotors
    Jan 2009
    Long Island
    Looks like this is turning into a "Dead End". I cannot find anything on timing the rotors "perfectly".
  1. need some help with rotors
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2009, 11:16 PM
  2. will these rotors fit?
    By 2000GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2009, 04:39 PM
  3. rotors?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2009, 09:37 PM
  4. EBC Rotors?
    By TyroElite in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2008, 09:33 PM
