Thread: Mystery Plug and Harness Swap Q's
Results 1 to 2 of 2
  1. #1 Mystery Plug and Harness Swap Q's
    GT Level Member tylerbinski's Avatar
    Canada
    ..Where does this plug go... I can't see it going far because its a short plug, I still have more stuff to install and put back so maybe its better half will turn up.. (plug is on the driver side, below the TB
    Also... After swapping the engine harness from a 97 regal GS (modified to work with an L67 motor , and using a 98 PCM) into my 97 GT....I have the following outstanding wiring that needs to be done.
    lastly, The plug on the right has different colored wiring, it plugs in okay, but I'd like to confirm before start up.
    Any one able to shed light on this.? Thanks guys!
  2. #2 Re: Mystery Plug and Harness Swap Q's
    Canada
    It was the A/C low pressure sensor..
    Still looking for info..
    Anyone have wiring diagram for a Buick regal ?
  1. Mystery problem with S/C
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2009, 01:08 AM
  2. Power steering pump mystery
    By cidknee in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:50 PM
  3. Afc 2.0 ext harness
    By zexed99gt in forum PCM Tuning
    Last Post: 12-08-2008, 09:30 AM
  4. 04+ Wiring harness
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2008, 03:22 PM
  5. Mystery Problem, Stalling And More !!
    By 02BlueGT in forum General Tech Discussion
    Last Post: 03-25-2008, 03:53 PM
