Thread: camshaft positioning sensory??
Results 1 to 2 of 2
  1. #1 camshaft positioning sensory??
    lutz, fl
    ok, so tuned up the car and it WAS running great....
    i have a 97 gtp. after the tune up everything was running fine, until a few days ago. it will crank, idle choppy for a few then die. after a few tries, it would start and run fine. now, its gone from that to while i'm driving just cutting off. after i tuned it up and cured to missfire code on cyl 6, i had the codes redone and it said something was up with the camshaft positioning sensor. i'm guessing this is whats causing my strife. any ideas? if this is it, how much am i looking at paying to have this fixed? any help is appreciated.
    larry
  2. #2 Re: camshaft positioning sensory??
    TDCRacing
    Guest
    You can chage it out your self and it cost as much as a new sensor. The sensor is located in the timing chain cover.
  1. Camshaft?
    By paratroopermatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 08:16 PM
  2. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
  3. low volts on throttle positioning sensor????
    By DONDON3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2008, 03:28 PM
