Re: Removing alternator housing
Is that metal shavings I see inside of the blower housing and at the base of the LIM?
Back when I hand built amplifiers, I used one of those soldering irons that looked like the pencil type on steriods, and for the connection to the 1/0 wire, a standard propane torch like used for plumbing jobs.:eek:
btw I was searching some of the forums I belong to, for the step by step on tearing apart the alternator that I've seen. For those that mess up theirs, have a bad one that needs replacing etc. A place called Afterthoughts does chromed 160 amp alternators or powdercoating if that is what you chose. Ill go back and see if I can find the thread, since it had a picture of the chromed one on a wbody.
IndeedSS
Awww come on Lee, you well know those help with sealing the case better.
SyntheticShield
I'm sure everything from the LIM on would find it tasty too. Engine Metamucil.:D
Here is the chrome alternator. It sure is pretty. Underhood dressup
I never signed up on the board and you cant see past the first page there as a guest.
SyntheticShield
eh... link isnt gonna work for anybody that's not a 3800 pro member... --- i tried to sign up once, but i dont think it's necessary to have to give my full name to some web form if i choose not to.
1 Attachment(s)
Ok here it is:rolleyes: I forgot about the restrictions.:o
Sorry I should have posted a link to where the alternator came from, althought it looks a lot like a Farnsworth project.
High Output Alternator (160 AMP GM)
Wow, 210 bucks. Guess it would be worth it if you need that kind of output.
arent the 9c1 impala alternators 140 amps?
may not help in the disassembly area, but would be a less expensive option for more oomph
Hmmm, that may be worth looking into.
Toasty
125 amp in the 9c1 iirc, but yes it help those looking to upgrade anyway. Apparently for a chrome version you have to call them first.
IndeedSS
hrmm.. i was thinking 140 in the 9c1... perhaps im wrong -- if turbocharged406sbc chimes in, he should know--- i still cant believe that he cut up a perfectly good VERY low mileage L26 out of an 04 9c1 -- cut it in to thin slabs :eek:
lol tho he did manage to take just about EVERY single useable piece from that 9c1.
Toasty
Noooooooooooooo, say it aint so!
Toasty
I just checked the Impala site and 9c1 is 125 and the stock 3.8 got the 102. I heard the SS got the 125, but I cant confirm that...yet...:( 102 stock.
IndeedSS
ah well... hmmm perhaps i was thinkin about the po-po prepped tahoes, those have 140's
Toasty
I only know the Impala stuff and not very well at that.
Is there any place to get the 9C1 alternator for a good price?
SyntheticShield
125 amp alternator Bosch
This price is almost as much as the 160 amp from Afterthoughtsauto though. I had better luck googling 2004 Impala SS alternator since there were police Impalas in the mid 90's.
One of the Impala guys bought the Bosch alternator and loves it, although I believe he purchased a higher amp one. His comments were comparing the Delco to the Bosch.
