Thread: 1.9 Modded Rockers or 1.9 Rollers?
Results 1 to 20 of 25
  1. #1 1.9 Modded Rockers or 1.9 Rollers?
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Im gonna be getting some 1.9s here soon but dont know which ones. Is there any advantages to having 1.9 rollers over the 1.9 modded rockers? Im going to really try to find some used ones before i think of getting new but if i cant find any used ill have to get new which i would really like to try to avoid. A racetronix fuel pump will be in the mix as well so i can drop to the 2.8 i have sitting here. The EWP will be going back in along with the 160 t stat i have laying around. A new stock rad will be put in followed with a coolant flush. And also a new alt bracket will be put on since this one went to **** already. Hopefully i can get it to the track this summer.
    enough of my babbling now.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Charles City, IA
    Stock rollers. Or small ratio rollers since you are planning on a cam again soon.
    SMGPFC Two Nipple General
  3. #3 Re: 1.9 Modded Rockers or 1.9 Rollers?
    GTX Level Member real diehl's Avatar
    Salina, KS
    Between rollers and modified units, the rollers are better.
    The roller tip reduces valvetrain friction, and puts let stress on your valvetrain components. As far as which one makes more power, it won't really be noticable.
    Again, aren't you running a cam? Don't run 1.9's with a cam.
    You could probably get away with a small cam like a VS and 1.7's or 1.8's for more lift, but I would be leery.
    A little more information on the valvetrain you plan on running would be helpful.
    signature removed for inappropriate content.
    -bio
  4. #4 Re: 1.9 Modded Rockers or 1.9 Rollers?
    He went back to a stock cam.
    If you have the money...just get 1.95's.
  5. #5 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Salina, KS
    I saw some Harland Sharp 1.9 or 1.95 rollers on Club GP.
    Might check those out if they aren't sold already.
    -bio
  6. #6 Re: 1.9 Modded Rockers or 1.9 Rollers?
    i decided to drop the cam idea and go with 1.9s. I know that when running a cam its either stock or if a person was doing the cam possibly some 1.7s but no cam for me anymore. Thanks for clearing that up for me blue. Whats the difference between 1.9s and 1.95s?
  7. #7 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Topeka, KS
    The Ratio.
  8. #8 Re: 1.9 Modded Rockers or 1.9 Rollers?
    well ya. i guess that was a dumb question. Lemme reword it. Whats so great about the 1.95s compared to the 1.9s? just a tiny bit more lift or?
  9. #9 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Salina, KS
    Quote Originally Posted by bbptech View Post
    Yes. Lift.
    -bio
  10. #10 Re: 1.9 Modded Rockers or 1.9 Rollers?
    SE Level Member jp2001gtp's Avatar
    hookstown PA
    here some info. might help if u plan on going cam in future.
    ZZ Performance
  11. #11 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Jan 1970
    Maquoketa, Iowa
    I've always been told to stay away from the harland sharps, but you might find some people out there with no problems, so its up to you. A roller is better, but modded rockers are pretty reliable. I would go with either modded 1.9's or 1.95 yella terras.
    When you get up into the 1.9 ratio or above, one thing you have to consider is valve float. You will not notice it until you see it on a dyno graph or if its real bad, you may notice it. You will need some heaver springs.
  12. #12 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Salina, KS
    I believe Abrasive is running Harland Sharps.
    Anything over 1.9's you're going to need springs.
    -bio
  13. #13 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Quote Originally Posted by FoSHO99 View Post
    i got an offer for some 1.84 rollers but id like to have more lift. Would it be a good idea to get 130s or would i be fine with 105s to eliminate valve float?
  14. #14 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Charles City, IA
    105's will be plenty. If you are not getting a cam get some 1.95 rollers.
  15. #15 Re: 1.9 Modded Rockers or 1.9 Rollers?
    ya im not gonna go with cammed idea anymore. Dont wanna pull the motor anymore for awhile so some rollers will do fine. I still have retainers and 6 105 springs. basically when i get them, just put them in, torque to spec and good to go? or do i need to adjust preload and what not?
  16. #16 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Charles City, IA
    torque to spec.
  17. #17 Re: 1.9 Modded Rockers or 1.9 Rollers?
    GTX Level Member crbquist's Avatar
    Massachusetts
    Just get the 1.9 modified rockers. You won't notice a difference between rollers and modified. You will also save $$ for more mods!
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  18. #18 Re: 1.9 Modded Rockers or 1.9 Rollers?
    Charles City, IA
    Quote Originally Posted by crbquist View Post
    you will notice a difference.
  19. #19 Re: 1.9 Modded Rockers or 1.9 Rollers?
    so i picked up some 1.9 Harland Sharp roller rockers with modified pedistals today. Can i use my ZZP 7.05 3/8 pushrods?
  20. #20 Re: 1.9 Modded Rockers or 1.9 Rollers?
