Thread: Boost gauge...
Results 1 to 11 of 11
  1. #1 Boost gauge...
    SE Level Member WayneG99's Avatar
    Apr 2009
    Buffalo
    What vacuum line do I use for a manual boost gauge on a 2004 GTP?
  2. #2 Re: Boost gauge...
    any vacuum line..since there is only one..
    (the one that goes BBV > FPR > LIM > MAP)
  3. #3 Re: Boost gauge...
    Odessa, MO
    Yup, and on both our GTP's I tapped into it between the LIM and MAP so it's nice and hidden in the back.
  4. #4 Re: Boost gauge...
    Apr 2009
    Buffalo
    ok thanks! just wanted to make sure.
  5. #5 Re: Boost gauge...
    Barksdale AFB, LA
    I think on his it would be BBV>LIM>MAP>MAP since they have no FPR (returnless fuel system) and two MAP sensors.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Boost gauge...
  7. #7 Re: Boost gauge...
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    So, cutting the stock vac line between the MAP sensor and the LIM is the best place? I was thinking of maybe switching out the 90* rubber connector that goes to the MAP with a T and running the line to the gauge that way. I just bought a new vac line assembly when I done the LIM gaskets and I would rather not cut into it. If my idea would not work, than just get a rubber T and cut the line and put it inline and run a plastic vac line to the gauge?
  8. #8 Re: Boost gauge...
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Quote Originally Posted by 98SilvermistGTP View Post
    any place is good most people like it there because it is hidden out of sight, i hooked mine up last night and just ran a T and took of that 90 that you are talking about and i haven't had any problems yet
  9. #9 Re: Boost gauge...
    Nov 2008
    Eastern KY
    Nice. That is what I wanted to hear. Did you run a hard plastic line for the boost gauge?
  10. #10 Re: Boost gauge...
    St. Louis
    yes i did
  11. #11 Re: Boost gauge...
    i put an extra T fitting on the MAP sensor input and continued the line into my car. realistically you can do it anywhere. i ran a soft rubber line and it works just fine.
  1. boost gauge and etc...
    By Charged97 in forum General Tech Discussion
    Last Post: 02-28-2009, 04:16 AM
  2. question about boost gauge on a 98 gtp
    By millfire517 in forum General Tech Discussion
    Last Post: 02-09-2009, 08:31 PM
  3. Boost gauge on 03 gtp
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:06 PM
