Thread: Gen V supercharger swap
Results 1 to 9 of 9
  1. #1 Gen V supercharger swap
    SE Level Member bhrfpa11's Avatar
    Nov 2008
    Palmer, Alaska
    so i am thinking hard about doing this and i was wondering about how much it would cost and what parts i would need. any help would be greatly appreciated.
    Black 2000 GP GTP: Rockford Fosgate all around, HID's, K&N FWI.
    <- yup. thats alaska.
  2. #2 Re: Gen V supercharger swap
    Prolly around $500-$1,000 for everything...not sure what you will need except a modded LIM, TB Adapter, New S/C Gasket...The Gen V will run the most...somewhere around 400-800 bucks IIRC.
  3. #3 Re: Gen V supercharger swap
    you need the blower and throttle body adapter.
    you can get a blower for $350 from an LKQ junk yard and the adapter costs $100 from ZZP.
    you have to open up the lower intake a little bit towards the snout, but that can be easily done by tracing a genV gasket onto the LIM and using a sawzall and dremel to cut it open.
    that is it. plus the new blower gasket.
  4. #4 Re: Gen V supercharger swap
    Jersey
    your also going to have to make a block-off plate for the evap. Unless your going N* t/b, your also going to have to block of the pcv nipple and run a breather.
    16' wrx sti- stock
  5. #5 Re: Gen V supercharger swap
    Nov 2008
    Palmer, Alaska
    anyone have a gen V blower that they are looking to part with by chance?
  6. #6 Re: Gen V supercharger swap
    Apr 2009
    Nassau County, New York
    dont you need a new intercooler?
  7. #7 Re: Gen V supercharger swap
    Banned - Busted For Scamming
    Feb 2009
    you could convert it by machining out 3/4" to the snout side.
  8. #8 Re: Gen V supercharger swap
    SE Level Member NickT'sGTP's Avatar
    Cedar Rapids, IA
    oh the beautiful Gen V. The whine is enough to make me cream my shorts.
    1998 Grand Prix GTP - 12.699 @ 108.84 - 1.931 60 ft - Gone.... but not forgotten....
    2005 Impala SS - 14.790 @ 94.35 - 2.262 60 ft - 100% Stock
  9. #9 Re: Gen V supercharger swap
    Quote Originally Posted by shape275 View Post
    For just swapping to a GenV blower...No.
    You just have to compensate pulley sizes on the GenV since it is more efficient. EG: You have a 3.4" setup on your GenIII blower. You will probably have a to run a 3.6" or 3.8" pulley on the GenV...less parasitic loss on the motor and makes just as much if not more power.
  1. Supercharger Pulley Swap [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 12-04-2011, 03:16 AM
  2. Supercharger ?s
    By screamingreenmonster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2009, 10:21 AM
  3. Supercharger oil?
    By stewartj1998 in forum General Tech Discussion
    Last Post: 03-03-2009, 09:54 PM
  4. supercharger
    By ldyzluvdis06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 08:53 PM
