Well my car starts then makes the fenderwell intake noise even though its warm i just got done driving it and now it dies. Any idea? NO DTC codes. Its a 2000 so should not have any fuel resister issues.
Why do u say its a 2000 so should not have any fuel resistor issues? I have a 2000 and ive had a fuel resistor issue before. Or do u mean u have already checked the fuel resistor and there was no issue?
I thought 99 and newer did not have this issue. is it in the pass fender? can i just jumper it i don't remember the fix for it.
yes its on the passenger side. from what i remember its by the fuse box. i can go check real quick for u to verify.
But that doesn't really sound like the problem.
no need for a resister. You can run around with the bent tap forever. I've had that done to my White GTP for about 7 years and that was the first mod I did to the Black GTP when I got it.
Love you man I was already mad because I though I needed allmost all my sensor thanks![]()
but will it be better replacing the resister
