anyone have any advice or write ups on the subject i have been looking for a while now but cant find anything
I dunno about home-porting the supercharger, but I did my LIM with a Dremel, router attachment, carbide "teardrop" bit, and A LOT of passes
Used a bit of plywood bolted to the LIM in various configurations as a guide:
An astute observation, but not a reason why one should not port the LIM if not porting out the H-bar.
My reasoning is that porting the LIM will expose more of the hot air in the LIM to the IC core surface, whether or not the H-bar is removed.
I can see it being potentially true that also porting out the H-bar is even better for exposing hot air to the IC core; but tell me, what harm will come of porting the LIM but not porting out the H-bar?
As for the s/c just do it like above.
Yeah...except you forgot to fill those slits in![]()
not done, havent forgot about them.
meh...minor details LOL
Here's the job Brian did on my blower:
looks like it wasnt taken down past the casting that far... i can still see those numbers lol. I tell you the best way to do it is a router, thats how i do it, and it turns out great, perfectly flat and use a straight edge. Takes 10 min tops.
Logan
y didnt you mill the whole thing then?
lol... ok
regular carbide, full speedcuts perfectly. little slower then phenolic obviously, but if you keep it braced up nice (takes more control then wood) then the bits last a while.
