Thread: just shuts off
Results 1 to 10 of 10
  1. #1 just shuts off
    May 2008
    staten island,NY
    the GTnowP is having a bit of an issue...if i go WOT (wide open throttle) and then let off the gas to apply the brake and brake hard the car will die. now it wont start up unless i put it in neutral, turn the key off and try it....i changed the fuel filter this passed saturday and its still doing it. im leaning towards ICM or something in the tune...any ideas? thanks-nick
  2. #2 Re: just shuts off
    Wausau, WI
    how big of a cam do you have?
  3. #3 Re: just shuts off
    May 2008
    staten island,NY
    stock cam, 1.8 roller rockers
  4. #4 Re: just shuts off
    Banned - Busted For Scamming
    Feb 2009
    Ever put that spacer on?
  5. #5 Re: just shuts off
    car knocking at all (KR)? how are your fuel trims?
    dude, i know you got a scanner.
  6. #6 Re: just shuts off
    May 2008
    staten island,NY
    no kr, fuel trims are on the money....im leaning towards the ignition control module. il have to have my tuner take a look at my file and see what the problem is
  7. #7 Re: just shuts off
  8. #8 Re: just shuts off
    Barksdale AFB, LA
    ICM or CPS would be my first guesses.
    2009 Subaru Impreza WRX STI
  9. #9 Re: just shuts off
    I am leaning towards the CPS
  10. #10 Re: just shuts off
    Feb 2009
    Camshaft position sensor? Im pretty sure it would still run. I could see how the CKP would make it stall.
  1. Engine shuts down
    By jvee44 in forum General Tech Discussion
    Last Post: 06-23-2009, 01:38 PM
  2. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
