Thread: o2 sensor
Results 1 to 8 of 8
  1. #1 o2 sensor
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    My car has 41,000 miles, would it be a waste to change my front O2 sensor?
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: o2 sensor
    TDCRacing
    Guest
    Quote Originally Posted by kissmyss View Post
    No it won't be a waste. As long as you send me the 50 bucks.
  3. #3 Re: o2 sensor
    Jan 2009
    ny
    I was hoping My gas mileage would increase, I performed a few mods and the is the same as when I purchased it low. The overhead console reads 11-12 city and 21-22 highway. I'm going to program the aeroforce to see what kind of mileage it say's I'm getting.
  4. #4 Re: o2 sensor
    TDCRacing
    Guest
    The DIC or overhead lies. The best way is the old way. Wich is figuring it up when you fill up and do a little math. If your fuel trims are off then the DIC will be off.
  5. #5 Re: o2 sensor
    I had 85K on my stock o2 sensor...threw in a Denso Race Tolerant o2...granted I went my the DIC but before I was getting MAYBE 23mpg on the HWY, with the Swap, I wasn't getting any LESS than 28 or so...
  6. #6 Re: o2 sensor
    unless your sensor is dead there is no reason to replace it.
  7. #7 Re: o2 sensor
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Not true. They get less precise with age, making them less effective.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  8. #8 Re: o2 sensor
    Quote Originally Posted by JoshMcMadMac View Post
    Like old people.
  1. bad map sensor?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2022, 06:58 AM
  2. maf sensor
    By betsgtp in forum General Tech Discussion
    Last Post: 04-21-2009, 02:15 AM
  3. Is it possible to run without an O2 sensor?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 06-19-2008, 11:45 AM
  4. L67 MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 06:00 PM
  5. MAF Sensor
    Last Post: 06-13-2008, 02:57 AM
