Thread: looking for build advice asap
Results 1 to 8 of 8
  1. #1 looking for build advice asap
    SE Level Member kirkkarem1212's Avatar
    waterford, MI
    right now i have a 2002 GP 3800 s/c block, or long block i guess? im looking to build it up but ive heard it would be a waste of time and money and i should just but a NA block or motor because id get more hp out of it. is this right? does it make any difference?
  2. #2 Re: looking for build advice asap
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    haha who the hell told u that. they must be retarded to say u would get more horsepower out of a N/A engine that a Superchargered engine.
    u would get more horsepower putting a N/A shortblock under L67/L32 heads and supercharger or putting a turbo on.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  3. #3 Re: looking for build advice asap
    Charles City, IA
    it all depends on how far you want to go and how much you want to spend. Answer that and we can help.
    SMGPFC Two Nipple General
  4. #4 Re: looking for build advice asap
    waterford, MI
    thats what i ment by saying that. using a na lower half and sc upper. and money not a big thing. i plan on taking my time on the build. not all at once.
  5. #5 Re: looking for build advice asap
    Charles City, IA
    keep the low comp block, fresh bearings, hone the cylinders, install big turbo cam double roller etc. then save up the turbo pieces you need.
  6. #6 Re: looking for build advice asap
    waterford, MI
    what type of supercharger is best?
  7. #7 Re: looking for build advice asap
  8. #8 Re: looking for build advice asap
    If your also stayin blower...keep the high compression N/A block...use the stock L67 bottom end low comp one for the high boostin turbo build
  1. constructive advice on genv build
    By foursixer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2010, 12:49 PM
  2. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  3. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
  4. Critical - need advice asap!!!
    By coolken84 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-09-2008, 12:02 AM
  5. Turbo build advice: GTP and GS mating..
    By LowlyfeGTP in forum Turbo
    Last Post: 05-27-2008, 11:29 AM
