Thread: What next?
Results 1 to 8 of 8
  1. #1 What next?
    SE Level Member Infinity9999's Avatar
    Dec 2008
    Brookfield, WI
    Currently have the mods in my sig. Running 18* of timing. I wanted to do something to get me down to a 3.25 or 3.2. I was looking at a ported blower, but then I'd probably need to get a ported TB to go with it, which might lead me to have to start looking at injectors, so I'm wondering if I should be looking at something different. I don't want to spend a ton of money, so an i/c is out of the question. Anyone have an opinion?
    04 Black GTP Comp G
    Mods: 3.2 pulley, SSIC, Wizair, AL104s, OBX headers, VS cam, 105# springs, 42# injectors, PowrTuner
  2. #2 Re: What next?
    if you only get a ported outlet then it wont matter about the throttle body. injectors really arent needed for you at this point if all youre looking for is ~3.2 pulley. at this point you need some form of cooling or more valvetrain (cam) mods. you already have all the other bolt ons...
    could invest in a meth kit, which is about $350. i love mine.
  3. #3 Re: What next?
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    I know you said an IC is out of your price range, but what about getting a phenolic one from minichopper6hp? He seems to do a pretty good job at building them and his price seems more than reasonable
    Minichopper6hp Phenolic IC
    Call me Brad
    '06 GT: Just a few mods here and there.
  4. #4 Re: What next?
    Dec 2008
    Brookfield, WI
    The ported blower I found is both in/out, so I'd probably need to be looking at a bigger TB. Technically I'd need a new pulley too (it comes with an MPS hub, but no pulley..I just have a press-on right now), plus another $20 for a 98+ vacuum harness. The problem I always seem to run into is all the extra stuff I need. I suck at customization, so plug and play is what I need.
    As for the intercooler, that looks nice, but again, I'd have to buy up the rest of the parts.
    Nick, how does the meth injection work on yours? Does it just spray automatically when you hit a certain boost level?
    04 Black GTP Comp G
  5. #5 Re: What next?
    Donating Users blowfishRus6's Avatar
    g.a.
    i dont have one but yea they work off of the boost with a controller. you set it to turn on at a certin boost.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: What next?
    Quote Originally Posted by Infinity9999 View Post
    it comes with a progressive controller that is hooked into the MAP. it has a 'turn on' setting and a 'full on' setting. i start spraying in the 6-7 psi range and peak it out around my peak boost which is around 10-11 psi.
    i havent played with it a ton, but im using it to keep my knock at zero and to keep my car consistent. i run straight meth so it adds a little octane to the mix as well. im running a 3.2 on a rocker car knock free which is about what youre looking for, right? would be something to look into. i run a devil's own progressive kit. most people run it from their washer fluid tank, but i wanted to leave mine functional so i bought a seperate tank. i probably have about $400 in my kit.
  7. #7 Re: What next?
    Dec 2008
    Brookfield, WI
    Yeah, I was looking at the Devil's Own kit after you mentioned it. I'd say I could probably get the complete blower for $225 maybe, add in a $20 vacuum harness and another $30 for a used pulley. Plus the supercharger gasket, injector o-rings, and TB gasket. That'd put me around $300 for just the blower setup.
    Modding sucks....you think you have things where you want it and then you get to thinking there's maybe one more thing you could do.....
    04 Black GTP Comp G
  8. #8 Re: What next?
