Thread: 3.25 Pulley Help
Results 1 to 20 of 20
  1. #1 3.25 Pulley Help
    Apr 2009
    El Paso
    Hi there folks, im new in this forum.
    Im looking for some help in to my 1997 grand prix GTP i have a few modz, PCM reprogram, 3.25 pulley, resently engine overhaul, modded intake, modded SC.
    But my problem its that my supercharger only trows 5 psi of the 10 psi, that the 3.25 pulley produces.
    Can anyone help me with my problem? i dont know what happened.
    Thanks a lot
  2. #2 Re: 3.25 Pulley Help
    May 2008
    staten island,NY
    3.25 is too small of a pulley. what is your complete mod list?
  3. #3 Re: 3.25 Pulley Help
    Banned - Busted For Scamming
    Feb 2009
    umm yea.... a 3.4 will give you 10 psi lol
  4. #4 Re: 3.25 Pulley Help
    X2 on the mod list...your car is probably slower than a 3.4" or 3.5" pullied car.
    You are most likely knocking and that is why you're not boosting right...
  5. #5 Re: 3.25 Pulley Help
    Apr 2009
    El Paso
    may I change to a 3.4 or 3.5 pulley?
    I read at zzperformance that a 3.25 pulley its good for a stock or sligthly modded GTP
    and how i fix the knocking to be usefull the 3.25 pulley
  6. #6 Re: 3.25 Pulley Help
    Barksdale AFB, LA
    You need a lot more mods to run a 3.25. You're not even safe to run a 3.4.
    2009 Subaru Impreza WRX STI
  7. #7 Re: 3.25 Pulley Help
    GT Level Member DWosik13's Avatar
    Detriot,MI
    Quote Originally Posted by s6dark6angel6s View Post
    you must of misread cause thats def wrong 3.5 is for slightly modded cars
    2002 BLACK GTP ... R.I.P.
    New Car 2009 Cobalt SS
    http://www.cardomain.com/ride/3352208
  8. #8 Re: 3.25 Pulley Help
    Barksdale AFB, LA
    Straight off ZZP:
    97-03 Grand Prix & 04+ supercharged Impala & Monte Carlo SS
    3.5 pulley totally stock car
    3.4 pulley Colder Tstat & spark plugs, downpipe, Cold air intake (still could have KR)
    3.3 pulley all of the above plus a VS cam, SS intercooler, or headers
    3.2 pulley 3.4 mods and a XP cam
    3.0 pulley 3.4 mods and a fullsize intercooler or an SS ic and a VS cam.
    Anything smaller than a 3.0 pulley will require a camshaft, headers, intercooler & injectors
  9. #9 Re: 3.25 Pulley Help
    You fix the knock by putting a bigger pulley on. Probably a 3.8"
  10. #10 Re: 3.25 Pulley Help
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    wow!! i would put the stock pulley back on asap!
    Going back to stock *GRANT built trans BLOWN w/17k*
  11. #11 Re: 3.25 Pulley Help
    Apr 2009
    El Paso
    Ok i'll try puting a 3.5, whats the original size of pulley? 3.6?
  12. #12 Re: 3.25 Pulley Help
    Donating Users blowfishRus6's Avatar
    g.a.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  13. #13 Re: 3.25 Pulley Help
    Apr 2009
    El Paso
    Ok guys, tnks a lot, i will notify you when i make the change and what happened.
  14. #14 Re: 3.25 Pulley Help
    how do you not boost "right"? you put the pedal down and it boosts no matter what pulley you have. it just boosts more with a smaller pulley.
    if it is leaking off 5 pounds of boost i say your BBV is bad, but i also agree with everyone else that the pulley is too small for your mods. you need a 3.5.
  15. #15 Re: 3.25 Pulley Help
    Barksdale AFB, LA
    The PCM is probably blowing boost through the bypass solenoid because of how much boost and knock it's seeing.
  16. #16 Re: 3.25 Pulley Help
    ...but the PCM doesnt do that...
    it limits boost on torque management and traction control...that's it.
  17. #17 Re: 3.25 Pulley Help
    Barksdale AFB, LA
    It also does it to protect the cat should it detect a condition that excess fuel is being dumped. I'm staring at the table that controls it right now.
  18. #18 Re: 3.25 Pulley Help
  19. #19 Re: 3.25 Pulley Help
    Apr 2009
    El Paso
    And how should i know if the BBV its working fine?
  20. #20 Re: 3.25 Pulley Help
    CT
    you might be thinking that your not seeing all your boost because your cars not as fast as you'd want it to be. Your best bet would be to get a 3.5" pulley and a scan tool.
  1. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
