i have a buddy thats a master tech at a BIG ford lincoln mercury suzuki dealership anyways. they have specialty tools. i know the SHO is supercharged right? do they have any special tools he has access to that will work on are pulleys?![]()
Thunderbirds had a blower on them. Unless he has a puller specifically designed to pull a pulley off of a Thunderbird with a m90 then i wouldn't use anything other than a puller designed for your blower.
i aint tried it yet but ive heard you go rent a pulley puller from autozone or where ever and remove the pulley that way. it will not be reusable tho.
oo yeah i was thinking about that GET IN THE ZONE.... AUTOZONE i can get discounts from my buddy ha
tbirds m90 are keyed, no puller required!!!
Logan
Any one up for betting on a taco-looking pulley when all is said and done?
Sinister Drag Designs in Joilet, IL can swap pulleys for 50$, according to their website. You can also rent a puller from ZZP for like $35 plus deposit. you get your deposit back once you return the puller. i wouldn't mess with the autozone puller if you have never done a pulley before and also because it doesnt have a backing plate.
well see i dont understand how the mps hub goes on?? thats what i was figuring i would just whack it on there. insight??
You have to have a special hub install tool as the puller is too big for the small hub IIRC...
maybe not idk...
