Thread: The Electrical Work Is Done!!
Results 1 to 13 of 13
  1. #1 The Electrical Work Is Done!!
    Oklahoma
    Well its finally all done. Had to do the following:
    1. Replace Ignition switch
    2. Install Ignition Saver Modification
    3. Replaced Blower Motor Resistor
    4. Re-wired gauges to passenger side fuse block with 'Add A Circuit' taps
    5. Tidied up the wiring under the dash with zip ties
    I need to replace the heater core and install my wideband kit so I can do a write up on that. It just takes time to get it all done.
  2. #2 Re: The Electrical Work Is Done!!
    Moore, Oklahoma
    Where does a guy get those add a circuit taps? Are your gauges still wired to the dimmer switch...
    Shawn W. Larsen
  3. #3 Re: The Electrical Work Is Done!!
    Oklahoma
    I got my add a circuit taps at Advanced Auto. And yes, the lighting of my gauges is wired to the dimmer. Seemed like the best thing to do.
  4. #4 Re: The Electrical Work Is Done!!
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    Are the add a wire taps as simple as connecting a wire to it and putting it in a fuse slot? And is there a specific slot to use? This sounds like a much better idea than hacking away at my new ignition switch to reconnect my gauges .
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  5. #5 Re: The Electrical Work Is Done!!
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by 1998gpgt View Post
    if you're needing power/ground/switched 12v, have you found the power drop accessory plug behind the glovebox? that's an easy way to get what you need. zzp i do believe even sells the mating connector for it.
  6. #6 Re: The Electrical Work Is Done!!
    McHenry, IL
    So just where exactly is the plug at? If i get under the dash will i be able to see it, or am i going to have to go through the dash and glovebox?
  7. #7 Re: The Electrical Work Is Done!!
    Oklahoma
    Yeah, I didnt see a plug under there when I was wiring stuff in, but I wasnt specifically looking for it either.
    That said, the add a circuit taps do just plug into the fuse panel where there are existing fuses. There is one fuse that is a power drop (10amp) and used that for one, then I used the power for the steering wheel controls (2 Amps) for the other one. The add a circuit taps maintain the existing circuit and, of course, add a drop for whatever you are wanting to wire in and already have the wire connected with a butt connector on it. Was quite convenient. Easy to do and does it in the proper way in that you get fused protection on the extra circuit you are adding.
  8. #8 Re: The Electrical Work Is Done!!
    SW Chicago Suburbs
    i need to dig and find it, but essentially, you lower the glovebox to the floor, and behind it is a large run of wire harness. taped up along there is an unused plug, with power, ground, and switched power... labeled as power drop, too.
    there was a picture up here in one of the threads, but i cant seem to find it.
  9. #9 Re: The Electrical Work Is Done!!
    Oklahoma
    I did see that large harness back there, but I wasnt digging into it to find a connector at the time.
  10. #10 Re: The Electrical Work Is Done!!
    Port Hope Ont,Canada
    Do you have any pictures of how you did yours Scott....
    I like the dimmer idea alot
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  11. #11 Re: The Electrical Work Is Done!!
    Oklahoma
    No, unfortunately. Time was kinda short so I wasnt able to stop and take pics as I went along and take the notes that I normally would. But I can get a shot of how it looks in the fuse panel now if that will help.
  12. #12 Re: The Electrical Work Is Done!!
    SW Chicago Suburbs
    SS--
    can you do me a favor? can you take a peak under the dash and see if you can make out the connector positions for the 12v constant and 12 acc lead used in the ignition saver mod? The connector rows/colums should be labled... i think they're C5 and D6 positions..... I'm doing a plug-and play (no cutting factory wires) version (can you tell that's one of my mantras?)
  13. #13 Re: The Electrical Work Is Done!!
    Oklahoma
    Quote Originally Posted by Toasty View Post
    SS--
    Now why didnt you do this BEFORE I cut mine. Can give infractions just because I dont like someone?
    Nah, Im glad you are like that because I sure prefer things like that myself. Not only is it safer and easier, it makes it easy to demod if needed. If I dont forget about it I will get that information for you.
  1. Why Does My Gas Gauge Not Work?
    By BLACKEDOUTGTP in forum General Tech Discussion
    Last Post: 05-15-2024, 09:07 PM
  2. Lots of electrical issues
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-31-2008, 11:14 PM
  3. Help please!!! Electrical system acting weird, Car won't start now!!
    By Tkuligowski in forum General Tech Discussion
    Last Post: 01-24-2008, 08:42 PM
  4. Will this work?
    By sra_chipmunk in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2008, 09:12 AM
