Thread: FPR vac fitting
Results 1 to 5 of 5
  1. #1 FPR vac fitting
    Barksdale AFB, LA
    How snugly is that fitting supposed to be? Right now it doesn't take much to move it up and down on the nipple on the FPR. I'm wondering if because it's so loose I have a slight vac leak there. It's loose enough that I'm not sure it wouldn't blow off under boost. It's not as secure as the fitting on the LIM or on the MAP sensor.
    2009 Subaru Impreza WRX STI
  2. #2 Re: FPR vac fitting
    mine isnt super tight either. i dont think they need to be. if youre worried about it slap a zip tie around it.
  3. #3 Re: FPR vac fitting
    Barksdale AFB, LA
    Word. Thanks bud.
  4. #4 Re: FPR vac fitting
    Moore, Oklahoma
    Mine is loose too, Even with a new vacuum harness. I just threw a small zip tie around it and have been fine. Actully I used small ones on every fitting on that vacuum harness... figured i'd might as well for the hell of it...
    Shawn W. Larsen
  5. #5 Re: FPR vac fitting
    Barksdale AFB, LA
    I threw a zip tie on it and I'm much more satisfied. Seems to work pretty well.
  1. Tranny thread fitting Information
    By UR LOSN in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-15-2017, 03:36 PM
  2. Fitting Part Numbers?
    By Scimmia in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2009, 09:47 AM
  3. Transmissions fitting
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 09:00 PM
  4. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
