Thread: 1404 code and EGR Valve
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #1 Re: 1404 code and EGR Valve
    Oklahoma
    Good Lord James, you have got to get your notebook legible so I can start reading it whilst I put it on the internet for everyone else. You are just chock full of fantastic information.
  2. #2 Re: 1404 code and EGR Valve
    hangover park IL, in the garage working on one of 12 3800's
    meh its the curse of being single for 8+ years (last gf pissed and moaned about me spending $$$ on a welder when she wanted jewelry...buh bye!!!!)
  3. #3 Re: 1404 code and EGR Valve
    SE Level Member AlphaBetaBase's Avatar
    Update: I performed the steps as required. Now I get two codes
    P1404
    P0403 -EGR Solenoid/Circuit malfunction
    I did some research and it appears not so much to be the EGR but the "motor" on it(?)
    Another issue could be a bad ground.
    Research still indicates replacing the EGR won't fix the issue. Suggestions?
    This has gotten really annoying.
    EDIT: The "Motor" is I believe was for a Nissan, so you can scratch that off.
    Page 63 of the document shows a diagram of the EGR. Does this help? No. Just showing it.
    http://www.autocenter.weber.edu/obd-...-RespFinal.pdf
  4. #4 Re: 1404 code and EGR Valve
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by AlphaBetaBase View Post
    P1404
    i'd run the steps again.. clearing both codes obviously
    just to rule it out
  5. #5 Re: 1404 code and EGR Valve
    Well, I repeated the steps and the P1404 didn't come back for a while.
    However, I got a P0171 and another P1404 code code thrown just yesterday. I'm going to nickname my car the "code generator". That's 5+ different codes so far from the car.
    Found a couple links from the searching.
    http://www.grandprixforums.net/f73/h...0171-1750.html
    http://www.grandprixforums.net/f65/f...ouble-962.html
    I followed the directions with the first link. The second link had a post where an EGR was the problem. With three code all pointing to the EGR, I bet the next code will say "Look, you cheap bastard. Replace my EGR value".
    I think this is a clear indication I just need to replace it.
  6. #6 Re: 1404 code and EGR Valve
    Saraland Alabama
    you have a leaking egr if the egr caused the P0171, which can also trigger other egr codes
  7. #7 Re: 1404 code and EGR Valve
    IC. So replacement is the way to go, eh?
    I could contact Ed but I don't mind paying for a new one.
  8. #8 Re: 1404 code and EGR Valve
    Saraland Alabama
    I doubt replacing it will help unless the valve itself is leaking. Get a can of seafoam and run it through the vacuum line it will show where the egr leaks (nice black smoke)
  9. #9 Re: 1404 code and EGR Valve
    Ha! found the issue with the P0171 code.
    I changed the EGR valve and the P1404 code hasn't come back but the P0171 does (Vacuum leak).
    http://images.highperformancepontiac...percharger.jpg
    http://www.gmperformanceparts.com/_r...OE_3800_02.jpg
    http://www.theautoshop.net/TrofeoEng...CNP_Trofeo.JPG
    The culprit is the hose connector broke off going from the S/C bypass value to this 3-prong connector that sits on top and to the back of the supercharger. Its the piece that is connecting to the brake booster.
    Just curious on what the technical name of this is. Was going to get one from Murray's tomorrow plus a new hose.
  10. #10 Re: 1404 code and EGR Valve
    SW Chicago Suburbs
    the 3 way piece on top of the s/c? you'll not likely find that at murray's... dealer or used parts...
  11. #11 Re: 1404 code and EGR Valve
    Called the dealer.
    Get this. They want $240 for that small plastic piece.
    This is officially the most overly priced item I've heard form a dealership.
  12. #12 Re: 1404 code and EGR Valve
    SW Chicago Suburbs
    Called the dealer.
    hello... Ed Morad?
  13. #13 Re: 1404 code and EGR Valve
    They're out of them.
    Called another dealership and they are $6.00. I'm pretty sure that other dealership got it wrong then.
    I should be good to go now.
  14. #14 Re: 1404 code and EGR Valve
    SW Chicago Suburbs
    cool!
  15. #15 Re: 1404 code and EGR Valve
    last update:
    Replaced hose and small plastic piece. No more codes. Code free is the way to be.
  16. #16 Re: 1404 code and EGR Valve
    PA
    last update:
    Glad to hear!
    2001 GSE
  17. #17 Re: 1404 code and EGR Valve
    SE Level Member red69p51's Avatar
    Feb 2009
    Indiana
    I too had recurring P1404 codes, combined with P0404 codes. Turned the problem was a bad vacuum hose to the evap purge valve! $.50 of vacuum hose will fix it, or you can spend $25 for the replacement hose assembly.
    ____
    '69 Mustang Fastback, 13.464 ET,105 MPH, 351W 3.50, tremec
    '01 GP-GT 4-dr 127K miles
    '05 Colorado XTreme
    69 Mustang
  1. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  2. Dont know what my paint code is
    Last Post: 01-23-2008, 03:15 PM
  3. stock valve renewing?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2008, 12:51 PM
  4. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
