Thread: Coolant Elbow Replacement on a 99-00 GTP?
Results 1 to 12 of 12
  1. #1 Coolant Elbow Replacement on a 99-00 GTP?
    Moore, Oklahoma
    It been awhile since I really tore apart the top half of the motor. I want to replace BOTH coolant elbow on my 99 GTP, and on my GFs 00 GTP (one of hers is leaking I think). How do I remove that piece that has both elbows attached to it? I know you have to removed it anyway to get access to the rear valve cover. How many bolts are there? Its been so long I can't honestly remember. I put rockers in the 1999 over 5 years ago...
    Shawn
    Shawn W. Larsen
  2. #2 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Oklahoma
    If you pull the alternator and that alternator bracket you will be able to replace both of them. Autozone carries them in the Help section if you need to get a set. As for the number of bolts, I dont remember exactly. I think it was three for the alternator and three for the bracket? I believe both were 15mm.
  3. #3 Re: Coolant Elbow Replacement on a 99-00 GTP?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I believe Scotty is spot on. Just watch the bolts when you remove them, iirc a couple are not the same length as the others.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Topeka, KS
    You are correct. Pretty sure on 15 mm too.
  5. #5 Re: Coolant Elbow Replacement on a 99-00 GTP?
    GT Level Member DuBob's Avatar
    Lititz, PA
    The alternator has 3 different length bolts holding it on, keep track which goes here because if you put a longer one where it isn't supposed to go, you'll send a bolt through the rear valve cover.
    As for the bracket, there are 2 visible bolts and one that's hard to see that's closer towards the power steering pulley. Those 3 are the same length though.
    As far as replacing the elbows, just pull them out of the alternator bracket....be sure to get them out completely because I have seen some leave a broken piece of plastic inside the bracket. Clean out the holes and install the new elbows with a little grease on the rubber o-rings, it helps them slide in easier.
    I get the elbows at Pep Boy's help section......they sell them for $4 for both while the dealer chargers over double that.
    One of the First: 2008 Liquid Red Pontiac G8 GT (hers)
    -Intake, Tune, Magnaflow Exhaust, 40% tint.
    -Next: Rims, lowered?, headers?
    One of the Last: 2009.5 Stryker Blue Metallic Pontiac G8 GXP M6 (mine)
    -Intake, Magnaflow Exhaust, 25% tint.
    -Next: Headers and tune.
  6. #6 Re: Coolant Elbow Replacement on a 99-00 GTP?
    I live here. UR LOSN's Avatar
    Rockford, IL
    drain coolant first.....then when you get alternator off, remove 3 bolts..and just simply wiggle and pull bracket away.....should just come right out.
    if at all possible take some pics....and make a "how to"
  7. #7 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Oklahoma
    Quote Originally Posted by UR LOSN View Post
    Good Idea, I dont think I have seen a really good HowTo for replacing both of the elbows.
  8. #8 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Rockford, IL
    HA!! beat ya to it......with the idea I mean....
  9. #9 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Oklahoma
    So you did, this time.
  10. #10 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Rockford, IL
    whats that suppse to mean? your already beating me on posts....I gotta have something
    LOL!
  11. #11 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Moore, Oklahoma
    Wish I had a camera, I would of done a How-To. I have one more chance when I do my 99 in a month or 2. Today I did my GFs 00. I honestly wish I didn't ask, As soon as I got the Alt off I figured it out instantly. Just 3 bolts equal length holding the bracket on. Took about 30 mins to do counting flushing + refilling the system...
    Shawn W. Larsen
  12. #12 Re: Coolant Elbow Replacement on a 99-00 GTP?
    Oklahoma
    Good job. Yeah its more labor intensive than anything.
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  3. Tefba coolant filters GROUP BUY !!
    By bayareagtp in forum Group Buys
    Last Post: 04-07-2008, 10:43 AM
  4. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
