Thread: Need Help with p0327 and p0332
Results 1 to 3 of 3
  1. #1 Need Help with p0327 and p0332
    Cocoa,FL
    Hey guys I am lost on what needs to be done next. I have both knock sensors detecting low voltage and can't seem to figure out why. I have replaced the front sensor with a working one (didn't fix it) and then I replaced the WHOLE engine wiring harness thinking that maybe the wires going to the sensors were bad no luck either. I also tried taping on the block to simulate knock on the motor and couldn't register anything on my scan tool
    So my questions are
    If I only replaced one sensor (front bank 1) would both still show as bad? (do they need to be replaced in pairs?)
    What else could the problem be if its not the knock sensors failing or the wiring?
    Is the PCM bad?
    Here is a list of all of whats done to the car
    9:5:1 Compression L67 Bored .20 over
    VS Cam
    3.4 Pulley
    PEM
    3" Full Exhaust
    ZZP stage 1 TB
    3.29 gears
    I run a 10.9 AFR at WOT and about 11-12lbs of boost
    Any help would be appreciated!!
  2. #2 Re: Need Help with p0327 and p0332
    TDCRacing
    Guest
    That's intresting. Never heard of this before.
  3. #3 Re: Need Help with p0327 and p0332
    Cocoa,FL
    Yea I know I can't find anything anywhere that someone has both knock sensors detect bad. It's normally one or the other never both. I know both are good I just can't figure out why the pcm is saying they are bad. I just ordered a overkill pcm to see if it is the pcm since I read something about the possibility of the computer being bad.
    Hopefully I install the new pcm and it cures the problem but if not........Guess Ill have to live with the problem.
