Thread: Module?
Results 1 to 3 of 3
  1. #1 Module?
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    My car is a turd. Its been cutting out off & on for a year now. I replaced 2 of the 3 coil packs so far. When I change one, it runs fine for a couple of weeks or a month. Then it starts the same crap all over again.( no mods) I think I want to change out the rectangle thingy that the coil packs sit on. What is that called? Can it be tested? Thanks! Lorri
    ignition module??
  2. #2 Re: Module?
  3. #3 Re: Module?
    Enid,Ok
    Thanks! I'm calling O'Reilly's.
  1. HELP:how to install used ABS pump and module
    By frankdatank0 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2009, 10:57 PM
  2. Bad Shift Interlock Module???
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 10:11 PM
