Thread: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
Results 1 to 10 of 10
  1. #1 Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Jul 2008
    Germantown, Maryland
    I have emissions check next week and I'm throwing this code. Do I need a whole new MAF or just the sensor?
    Awhile back my car was riding real rough and it had a wild idle. I was throwing this code then. I unplugged the sensor way back when and haven't had a problem since running on the MAP.
    Point is I won't pass the emissions check next week without getting this fixed.
    I'm also throwing the Throttle Position Sensor code as well but that's because I was fooling with stuff. I'm thinking that was my fault but it still was registerring on my HPTuners even after I hooked it back up.
    Any help is appreciated! Is there anyways I can prevent the car from throwing codes by using the HPTuners at least to get through my emissions? Thanks!
  2. #2 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Jul 2008
    OBD-II Trouble Code: P0102 Mass Air Flow (MAF) Circuit Low Input
    That should help me.
    Im going to put the stock intake box on for now to see if that works
  3. #3 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Feb 2008
    Try cleaning your MAF sensor.
  4. #4 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Jul 2008
    I will try that first...
    Any info on tricking my computer so I can pass the emissions?
  5. #5 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Drop the stock tune back on there for a minute and see if anything changes.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  6. #6 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Jul 2008
    Quote Originally Posted by JoshMcMadMac View Post
    Thanks man, yea I was thinking of trying this. Ill see how it works.
  7. #7 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    You may want to check the connection at the MAF sensor.. This code, P0102, is caused by an abnormally low reading from the sensor. The few times I have seen it, the wires were loose/damaged/etc (causing to the signal to drop to 0 when driving).. Or the sensor itself is failing.
  8. #8 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Jul 2008
    Quote Originally Posted by bilemke View Post
    Yea I inspected them and everything looks fine, but maybe its internal in there wires or sensor or something.
  9. #9 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Aug 2008
    Long Island, New York
    this just happened to me... ses keeps goin on and off... buying a new MAF today
  10. #10 Re: Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    Aug 2008
    got my new maf in the car yesterday... ses light has gone off... now it better STAY off. gotta scan for thayt stupid p0102 code again when i can bring my car into class
  1. getting the P0102 code... what do i do?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 09:38 PM
  2. P0102 code help!!
    By boostjunky in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 09:50 PM
  3. Mass air flow sensor
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2008, 01:36 PM
  4. code p0102
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 12:09 PM
