Thread: For those of you that took apart a Gen V
Results 1 to 9 of 9
  1. #1 For those of you that took apart a Gen V
    Jersey
    I finally got my s.c taken apart (snout bolt stripped ) to clean and throw in a new coupler...When i removed the s.c in 3 pieces i noticed there wasn't a gasket around any of the mating surfaces. I checked with the stealership and they don't know anything about it (they only sell it as a complete s.c). Im trying to figure out if i should use squeze out gasket or do I even need to
    16' wrx sti- stock
  2. #2 Re: For those of you that took apart a Gen V
    Bastard Reptile's Avatar
    Kansas City, MO
    The surface where the rotors slide into the case doesn't need to have anything added to it, but you'll want to use an anaerobic gasket maker for the snout side. Use sparingly, because it will squeeze out like crazy, but make sure you get the entire surface covered. Tighten down, and give it a few hours to cure before you put any fluid in.
  3. #3 Re: For those of you that took apart a Gen V
    Jersey
    Thanks dude! Would you happen to know the torque specs on the snout?
    16' wrx sti- stock
  4. #4 Re: For those of you that took apart a Gen V
    Kansas City, MO
    I think they are 15 ft/lbs. Don't have my sheet in front of me at the moment.
  5. #5 Re: For those of you that took apart a Gen V
    Jersey
    Thanks dude you helped me out a lot
    16' wrx sti- stock
  6. #6 Re: For those of you that took apart a Gen V
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    how much on average is a gen v blower. im goin to be looking into getting one after my headers, & dont want to over pay.
    ty
    Going back to stock *GRANT built trans BLOWN w/17k*
  7. #7 Re: For those of you that took apart a Gen V
  8. #8 Re: For those of you that took apart a Gen V
    Jan 2009
    westport maSS
    thanks man! ive been calling a few around my area but no luck finding a genV yet ! now i know around how much to save up for one!
  9. #9 Re: For those of you that took apart a Gen V
    TDCRacing
    Guest
    you can find them from an LKQ junkyard for $350.
    I got mine from there with 42,000 miles for 325.00 shipped.
gen
