Thread: Engine spudder at full throttle
Results 1 to 7 of 7
  1. #1 Engine spudder at full throttle
    SE Level Member basshead42's Avatar
    Toledo, OH
    So I'm runnin around in my GTX today and I'm screwwin around with a Dodge Charger R/T on the road. I totally stuff the pedal and the engine started like spuddering or shaking and it just totaly ran like crap till i got off the pedal. Its never done this so I'm like ? What could be the problem?
  2. #2 Re: Engine spudder at full throttle
    SE Level Member 1bad3800's Avatar
    Jan 2009
    bensalem pa
    plugs and wires it happens 2 me also it drove me nuts !then i just changed trhem what modds do u have done?
  3. #3 Re: Engine spudder at full throttle
    Toledo, OH
    I have the 3.4 pulley, ngk iridium plugs 2 ranges colder, msd wires, dhp 1.0 pcm, u bend delete, 2.5" cat back exhaust, ram air. I put these plugs in like maybe 2 yrs ago. time to maybe change?
  4. #4 Re: Engine spudder at full throttle
    GT Level Member DWosik13's Avatar
    Detriot,MI
    might be a dirty MAF
    2002 BLACK GTP ... R.I.P.
    New Car 2009 Cobalt SS
    http://www.cardomain.com/ride/3352208
  5. #5 Re: Engine spudder at full throttle
    Toledo, OH
    I messed with it a little lastnight. I let the car cool down for a bit and took it out. I stuffed the pedal and the acceleration was sweet, no spudder. So ?
  6. #6 Re: Engine spudder at full throttle
    SE Level Member mikroehl's Avatar
    Nov 2008
    bradenton
    hmm strange how did u clean it? i am having the same problem
  7. #7 Re: Engine spudder at full throttle
    Toledo, OH
    I didnt clean anything. I just let the car cool down and took it out again. So i dont know if a heat related issue or what. I have a trans temp guage and the trans was pretty hot. I still have the factory 195* t-stat in so im gunna order the 180 and see how that works. Probobly should have done this a long time ago.
  1. HELP Not making full boost
    By 1slowhatch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:31 PM
  2. small spudder after strt caused by 02 sensor?
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2008, 08:53 AM
  3. Did the LIM this weekend, not getting full boost, and getting hot... wtf?
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 10:18 AM
  4. gas gauge stuck on full
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 02:10 PM
  5. should of bought the full size ic
    Last Post: 07-20-2008, 07:27 PM
