Thread: General Gen. V blower swap questions
Results 1 to 11 of 11
  1. #1 General Gen. V blower swap questions
    There is a pretty good writeup on the other forum, but I am looking for some more info.
    Will a Gen.V with aftermarket fuel rail provisions, fullsize 2.5" intercooler, ZZP N* adapter, and 2000+ N* throttle body clear the factory hood? I read that the adapter plate and throttle body needs to be flipped?
    Also, with the 97 alt and bracket, will I have issues? Supposedly this combination causes issues. If you have made it work with a 97 or 98, post up please!
    Thanks.
    - Drew
    Last edited by GTPrix; 03-02-2009 at 09:08 PM. Reason: more details regarding setup
  2. #2 Re: General Gen. V blower swap questions
    Wow nobody knows?
  3. #3 Re: General Gen. V blower swap questions
    May 2008
    staten island,NY
    what year is your car? the throttle body should clear the hood, i have a N* on mine and i have no issue. are you running an intercooler?
  4. #4 Re: General Gen. V blower swap questions
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    X2, are you going to run an intercooler? The clearance gets VERY close when it comes to the N* adapter. Also flipping it upside down helps with the running of the throttle body cables IIRC.
    On your other question: yes you will run into problems with a 97-98 alternator. I suggest upgrading to 99+ for the swap
    For all your 3800 needs:
  5. #5 Re: General Gen. V blower swap questions
    Updated first post, sorry I should have been more specific.
    I have a Stage II Gen III intercooler, which raises everything 2.5".
  6. #6 Re: General Gen. V blower swap questions
    May 2008
    staten island,NY
    i think it should fit
    x2 with changing to the 99 style alt
  7. #7 Re: General Gen. V blower swap questions
    Quote Originally Posted by QwikGT View Post
    Care to back either of these statements up? Do you have an intercooled Gen V?
  8. #8 Re: General Gen. V blower swap questions
    Orange County, NY
    I don't think it will fit without flipping it over. Even WITH flipping it over it will be a tight fit.
    And yes, he should switch to the 99+ setup IMO
  9. #9 Re: General Gen. V blower swap questions
    Donating Users blowfishRus6's Avatar
    g.a.
    is the gen V taller than the gen III???
    some guys intercooler set ups fit, some dont. small fabrications or just a bigger hood is nessicery.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  10. #10 Re: General Gen. V blower swap questions
    Jersey
    I came across this pic on Dubob's website thats dedicated to his GP.
    It looks a little bit taller, its definitly bigger but its hard to tell with it bolted to the LIM.
    16' wrx sti- stock
  11. #11 Re: General Gen. V blower swap questions
    g.a.
    yea the gen v is bolted on the lim. hard to tell.
    its slow.
  1. Got some questions about the top swap??
    By biggmman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 06:24 PM
  2. what is required for a gen 5 blower swap?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:55 PM
  3. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  4. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
