Thread: What Gap For TR8's
Results 1 to 18 of 18
  1. #1 What Gap For TR8's
    GT Level Member a3gtp's Avatar
    Feb 2009
    Salter Path, NC
    I'm caught between buying TR8's and TR8 Iridiums. I know the Iridiums last a while but I hate the fact I can't gap them. Anyone have an opinion on either?
    Also what gap should I run if I buy the TR8's (non-iridium)?? :
    Car will have full exhaust, 3.25, and misc other little things, no motor work for the moment
    If they catch you in the back seat trying to pick her locks they're gonna send you back to mother in a cardboard box.
  2. #2 Re: What Gap For TR8's
    from what i have read. u want to run copper plugs.
  3. #3 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    Copper, ok I'll look into that.
    Anyone have experience with running the TR8's? Iridium or not
  4. #4 Re: What Gap For TR8's
    SE Level Member Sinister Drag Designs's Avatar
    NGK plugs are of very good quality. The real question is what setup are your running to need TR8's?
  5. #5 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    Its says what mods in the first post, nevermind, I'm just going to buy the iridiums
  6. #6 Re: What Gap For TR8's
    TDCRacing
    Guest
    You need to buy copper plugs is you are not N/A
    Gap should be around .045
  7. #7 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    ok, name a plug thats copper and 4 heat ranges colder than stock. And one 3 stages colder also if you wouldn't mind.
    Which should I run; 3 or 4? with 14 ibs of boost and full exhaust and all other supporting mods, in a warm climate?
  8. #8 Re: What Gap For TR8's
    TDCRacing
    Guest
    My suggestion is AL103's or a Tr8 non platnum plug. All of those are copper plugs.
    Remember Colder is not always better. You want to run the hottest plug you can without getting and detnation from it.
  9. #9 Re: What Gap For TR8's
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Someone want to tell me what's wrong with Iridium plugs in a FI application? AFAIK, they don't have the negative effects of platinum while having the longer life.
    On the gapping issue, the reason they say not to gap Iridium plugs is because the electrode is so fragile. If you're VERY careful, you can adjust the gap.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    I'm thinking TR7 iridiums if I go with a 3.3 Pulley
    And TR8 iridiums if I go with the 3.25
    Anyone that knows the gtp's well have anymore input?
    Like I said before the car will have full exhaust, intake, and all other supporting mods besides an i/c, will I knock with a 3.25 with these mods?, I currently run a 3.4 with 1* kr max (yes I scanned)
  11. #11 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    Going with the 3.3 and TR7IX (Iridiums) Anyone that knows this car "well" object?
  12. #12 Re: What Gap For TR8's
    tr6's.
    With that setup you will foul the plugs alot quicker with anything colder.
    The very small amount of knock reduction you will see with tr7s over tr6s will not matter when they foul out quickly and then you have more knock and random misfires.
    nothing wrong with iridiums but for how much they help its not worth the cost most of the time.
    What do you mean by full exhaust?
  13. #13 Re: What Gap For TR8's
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    TR6's are fine, like mentioned above they won't foul near as fast.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  14. #14 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    Fine I'll go with the TR6's again, what gap for 3.3 pulley and full supporting mods?
  15. #15 Re: What Gap For TR8's
    Topeka, KS
    I'm not quite sure why you are wanting to go so cold on the plugs or anything besides Copper. I would just buy Autolite 104's and be done with it. Also I'm not positive you have enough mods to run the 3.25 all the time. I personally have very similar mods as you if not more and still don't run my 3.25.
    Personally I'd rather be safe than sorry. But do what you want it's your car.
  16. #16 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    Quote Originally Posted by rynoman03 View Post
    Yeah I know I'm going with the 3.3 and when I do install it I will have much more done to the car.
    My only question still left is what gap should I run with either 104's or Tr6's???
    With a 3.3, headers, 3" D/p, ZZP catback, CAI, TB Spacer, ZZP T.Body and more (probably SSIC)
  17. #17 Re: What Gap For TR8's
    Feb 2009
    Salter Path, NC
    104's at .52
    Sound good?
  18. #18 Re: What Gap For TR8's
    TR6s at .054 sound fine. You might have to play with the gap a bit to see whats best for your setup, but thats a good start.
gap, tr8
