Thread: Nylon Fuel Line Repair
Results 1 to 6 of 6
  1. #1 Nylon Fuel Line Repair
    Nov 2015
    TX
    Chats
    The steel quick connect on the feed line stared seeping. I got the popular Dorman 3/8 nylon repair "kit", BUT ... I want to shape it like the steel OEM 2hich has a pretty tight S bend within a few inches of the connector. I tried heat gun and boiling hot water to soften the line, but can't come close to achieving the desired bend without kinks.
    I don't like the way the line contacts the evap solenoid without the S bend.
    Any suggestions? Is there a better solution?
  2. #2 Re: Nylon Fuel Line Repair
    St. Louis
    Chats
    Honestly I would just look for an OEM line to replace the entire piece. Delt with this on my friends 01 GT when it decided to keep leaking even after replacing the o-rings in it. Granted it's not the S/C version but still the same principal. Likely the other W-body S/C cars in that year range would work if you can't find one specific to the 98 GTP.
  3. #3 Re: Nylon Fuel Line Repair
    Chats
    243824
    if you have not cut the stock line yet, swap the o rings inside the fitting.
  4. #4 Re: Nylon Fuel Line Repair
    Nov 2015
    TX
    Chats
    Correction... The quick connect it steel but the line with the S bend that I need to replicate is nylon. That means there must be a way to make such bends without kinking the nylon.
    Any ideas would be appreciated.
  5. #5 Re: Nylon Fuel Line Repair
    Nov 2015
    TX
    Chats
    I tried replacing the orings but that was unsuccessful. I cut the line when I found the Dorman repair kit. SMH Now wish I had thought about it more.
    I found aftermarket line kits from linestogo.com, but they only sell complete line sets. They run ~$200 which isn't bad but seems overkill since my issue is just a 6" piece with a connector. 🙄
  6. #6 Re: Nylon Fuel Line Repair
    St. Louis
    Chats
    Double check my part# but I believe the GM part is 10427649. If so, I found one here:
    Classic Chevrolet Grapevine Pre-Owned
    2501 William D Tate Ave
    76051, Grapevine, TX
    +1 800-259-1200
    Buy GM Performance Parts & Accessories | National GM Parts
    Pipe
    OEM part number: 10427649
    Fuel feed
    $97.62
  1. Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
    By suitercrew in forum Wanted To Buy - Parts
    Last Post: 04-11-2017, 10:13 PM
  2. Size of nylon fasteners
    By 310toumad in forum General Tech Discussion
    Last Post: 11-02-2015, 03:19 PM
  3. Vacuum line repair MacGyver style
    By SJAndrew in forum General Tech Discussion
    Last Post: 09-04-2012, 11:46 AM
  4. Plastic fuel line repair?
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 08:50 PM
  5. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
