Thread: Methanol Controller Vacuum Line
Results 1 to 7 of 7
  1. #1 Methanol Controller Vacuum Line
    Feb 2019
    ON
    I recently picked up an older Snow Performance water/meth kit that uses a VC-100 controller. There's a nipple on the controller to run to a vacuum source to turn on the controller (needs 5 psi). I was just wondering where you guys who are running meth have run that line to.
    I've read of people using the brake booster as a source but I was wondering if I could use the nipple on the boost solenoid. Any help is appreciated. Thanks guys!
  2. #2 Re: Methanol Controller Vacuum Line
    i put a T in the line from the lim under the snout before the map sensor to my aem meth controller.
  3. #3 Re: Methanol Controller Vacuum Line
    Feb 2019
    ON
    Thanks man! I was hoping you'd chime in haha. Do you happen to have a picture? I'm a visual learner lol
  4. #4 Re: Methanol Controller Vacuum Line
    not really. you just cut the line and put a t in a open area to work in.
    mines in this birds nest lmao
    https://youtu.be/Hwb9gDgehhM?t=11
  5. #5 Re: Methanol Controller Vacuum Line
    Feb 2019
    ON
    Thanks Scotty I really appreciate it man. One more question if you don't mind.
    Where did you install your nozzle? I was thinking of going 6-8" ahead of the throttle body
  6. #6 Re: Methanol Controller Vacuum Line
    the gen 5 i cant seem to find a close up pic. but the black line you see looping over the intake tube is the meth line, i drilled and tapped the blower in the flat area near the bbv and put it in there.
    Methanol Controller Vacuum Line-20190207_170825-jpg
    the gen 3 i used a zzp tb spacer, notched the side drilled and tapped. two inches to the left is where i drilled the case in the gen 5. the opening of the blower there is about as big of a area as you get. you want it to spray not puddle up. also when you drill and tap it, work the tap in and do test fits with the injector. its a npt tap aka tapered and you need the tip of the injector to be flush or just a bit past the inside wall so when it sprays the mist clears the tapped hole. if you tap it to deep its easy go to far and the injector will not get tight and just strip out. so little bit by little bit testing along the way is the safe way. when you run water through it to make sure the lines and tank are clean you can run the water through the injector via the pump and you'll see just how much it sprays and how it umbrellas off the jet. my aem injector did a 3 foot wide spray on the large jet. left a puddle on the ground lol
    Methanol Controller Vacuum Line-141-jpg
    Methanol Controller Vacuum Line Attached Images
  7. #7 Re: Methanol Controller Vacuum Line
    Feb 2019
    ON
    Hell yeah Scotty! Thanks so much man! We're certainly lucky to have you on here
  1. boost reference line for meth injection controller
    By chrisrexmandie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2021, 02:07 PM
  2. What vacuum line is this??
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 12-19-2013, 07:53 PM
  3. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  4. Where is the vacuum line??
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2009, 01:04 AM
  5. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
