Thread: 04 grand prix no crank no ignition power
Results 1 to 12 of 12
  1. #1 04 grand prix no crank no ignition power
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    Bought an 04 comp g gtp with 134xxx mi got it was told needed a battery a starter and an icm took all those part from 99gtp got the parts installed went to try and start nothing when i put tge key in the ignition the dic read key in ignition and the mileage tried starting nothing but a clicking noise from the passenger side fuse box for the rap fuse or relay the fuel pump primes check all fuses they are good went under the vehicle amd jumped the starter car turned over just not when i use the key
    Any help greatly appreciated
  2. #2 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
    Heres a link to video of me trying to start the car
    04 grand prix no crank no start - YouTube
  3. #3 Re: 04 grand prix no crank no ignition power
    check the neg cable ground block pos thing off the battery. its know to not work well.
    if that checks out. put a test light to the purple wire on the small stud on the starter, if it lights up when you turn the key to crank that part is working, next step is jumping the starter, bridge a screw driver to the small stud with the purple wire to the large stud with the bat pos cable bolted there. it should crank once bridged. ( it will throw sparks) if it dont crank the starter could be bad, or we're back to neg and pos cable issues.
  4. #4 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
    Thanks the car will crank if i jump the starter. or the crank relay if i us a piece of wire and brigde 30 with 87
  5. #5 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
    Heres a video of car trying to crank
  6. #6 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
  7. #7 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
    When i removed the ignition relay my dic started working but not my instrument cluster #37 outside fuse box
  8. #8 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
  9. #9 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
  10. #10 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
    Got the car started finally by juggling ghe key cylinder
    https://youtu.be/67bGP52Q7v8
  11. #11 Re: 04 grand prix no crank no ignition power
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by 97gtp01gt99gt View Post
    and here i was reading thinking, "sounds like it could be the ignition."
    glad ya got r runnin!
    08 grand prix NA3800
  12. #12 Re: 04 grand prix no crank no ignition power
    Sep 2018
    Saint Louis
    Right on
  1. 1999 grand prix won't crank
    By dg8srt in forum General Grand Prix Discussion
    Last Post: 09-03-2014, 05:27 AM
  2. 2004 Grand Prix No Start No Crank
    By Charles20212 in forum General Tech Discussion
    Last Post: 06-14-2014, 05:41 PM
  3. 2004 Grand Prix, No Start, No Crank! Help!
    By jbybee4 in forum General Tech Discussion
    Last Post: 04-01-2014, 05:49 PM
  4. 1998 grand prix GT wont crank
    By li0nhe4rtt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2010, 04:23 AM
  5. 1995 Grand Prix has no power to ignition
    By ih8mygp in forum General Tech Discussion
    Last Post: 08-21-2010, 03:29 PM
