Thread: Need to replace plastic line and having an issue.
Results 1 to 9 of 9
  1. #1 Need to replace plastic line and having an issue.
    GXP Level Member ryangtp89's Avatar
    Maine
    I know this thread is kind of worthless but i need to know where i can find some new plastic lines. I broke one while i was changing my plugs last week, I'm pretty sure its a vaccum line because my boost gauge isnt reading accurate, it us to be accurate because as soon as i get one psi one bar would show up on the boost gauge on the dic. I'm also having shifting issues, even though my car is a 1999 and its electronically controled and not by vaccum. My tranny is a triple edge tranny i just got not 2 long ago. Well it sometimes doesnt like to shift into 4th. Like when i first start driving it, it drives great but as soon as i romp on it and give it wot then i let off of it then i will stay in high rpm and i have to pretty much give it wot to get it to shift to 4th. and sometimes when im crusing it stays in higher rpm like 50mph will be at a little over 2k rpm. Now idk if it has anything to do with my tps. If i have to do a case learn or something. I just installed a new tsp on my zzp stage one throttle body cause the tps on it had a good size crack on it so i replaced it. When i first installed it i didn't put it in the right postion and it was idleing at 3k lol, soo i postioned it so it idles just below a grand. But anyways the line i broke is above the s/c, i broke off may be a half inch of it, it has two nipples on it, soo what i did was cute the rubber hose where it broke inside and just slip it over the plastic line, and its not really secure soo i need to just get a new line. Also the tranny doesnt act up all the time like that. And it just started doing that as soon as i replaced the tps and broke that line. I haven't asked trannyman about this yet untill i replace the line and see if i do need to do a case learn on the tps first.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: Need to replace plastic line and having an issue.
    GT Level Member shaferz's Avatar
    Forrest IL
    What?
    If you need new vacuum lines, go to ANY autoparts store. Incorrect MAP sensor readings (which will happen if you broke a vacuum line) will cause all sorts of driveability issues.
    99 GTP = 12.936 @ 112.12 2.16 60'
    06 TBSS = STOCK
    07 GXP = STOCK - ordering SSC's
  3. #3 Re: Need to replace plastic line and having an issue.
    TDCRacing
    Guest
    Yeah just replace it with regular rubber hose. Oreilly's (6 ft for like 3.00)
  4. #4 Re: Need to replace plastic line and having an issue.
    Maine
    wish i had a o'reily's but advance auto is good enough
  5. #5 Re: Need to replace plastic line and having an issue.
    Barksdale AFB, LA
    While we're on the subject, anyone know a store that carries a direct replacement for the T-fittings (like the one on the LIM)? The one I have has a split in it and I can't find one that seems to match at the auto stores.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Need to replace plastic line and having an issue.
    Maine
    if its a big issue and if you cant find it for awhile just put some super glue on there.
  7. #7 Re: Need to replace plastic line and having an issue.
    Charles City, IA
    Mines held together with RTV lol
    SMGPFC Two Nipple General
  8. #8 Re: Need to replace plastic line and having an issue.
    Maine
    i was acutlly gonna put some rtv on my coolant recovery bottle cause i put a hole on it but i couldnt find any soo im still drving around lol
  9. #9 Re: Need to replace plastic line and having an issue.
    Feb 2008
    Quote Originally Posted by Sabrewings View Post
    Go to Auto Zone and check there. They have an assortment kit with 4 or 5 different ones, I think there are some straight ones in there too. My memory is foggy, but I'm pretty sure I saw some t-fittings in there.
    Otherwise, you might have to get the plastic Ts and use little pieces of hose.
    Hope this helps.
  1. Fluid cooline line replacement issue
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2013, 11:50 AM
  2. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  3. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
  4. Repairing plastic storage case?
    By Toasty in forum Off Topic Discussion
    Last Post: 05-16-2008, 11:14 PM
  5. how do you take this black plastic piece out?
    By nemesis in forum General Tech Discussion
    Last Post: 04-25-2008, 06:21 PM
