Thread: Running Rich 04 GTP
Results 1 to 6 of 6
  1. #1 Running Rich 04 GTP
    May 2021
    Melbourne Fl
    My 04 GTP comp G has been running very rich recently to the point I stopped driving it so I wouldn't mess up the Cat. I don't know if they are related or if it is coincidence but the throttle position sensor went south at about the same time causing a lower power warning. I replaced the pedal assembly and the error codes are gone but ever since I've been extremely rich.
    I needed to replace the lower intake due to a slow coolant leak so while I was doing that I replaced the upper O2, MAP, BAR, Injectors and MAF along with new spark plugs/wires since most of that needed to come out anyway and most of them were original. But none of those were the cause. The only mods are a CAI, front power log and a ZZP 3" downpipe that have been on the car for years.
    STFT and LTFT are in the -20s most of the time. There doesn't seem to be an exhaust leak anywhere. I tried finding what the fuel pressure should be for the 04 with the return less system but I have found a lot of conflicting numbers during searches from 42-50psi? So if someone has a shop manual with those numbers I'd appreciate it. - Thanks
  2. #2 Re: Running Rich 04 GTP
    hangover park IL
    the deadhead systems run up to 52psi base pressure, 48-52 is OE spec iirc.
    im going to say that if your O2 is a newer denso/ngk/acdelco (please tell me its not a bosch-they dont play well with out cars for some reason) and the maf is clean that im going to say your PCM was likely tuned for a 3.4 or some other mods and the car was demodded and not retuned to stock .bin file.
    a pree o2 exhaust leak would allow oxygen intot he exhaust and the pcm would go into + fuel trims believeing the engine was running lean.
    also put back on your OEM MAF/map/baro sensors ive had lots of oddities with "reman" and new parts....including ICM's
    ~James~ Psychotic Gearhead
  3. #3 Re: Running Rich 04 GTP
    hangover park IL
    and it wont damage the cat. the PCM is correcting the hardwritten tables by removing fuel (it will go to 44% change after it hits the 22% "wall" for long enough) to keep the mixture at stoiciometric.
    keep in mind that the TPC/MAP(and baro)/MAF and O2 are "trusted" sensors, so the pcm ASSuMEs they are correct even when they may be skewed by age/contamination.
    the O2 is the primary datapoint for trims....so make sure its good.
  4. #4 Re: Running Rich 04 GTP
    May 2021
    Melbourne Fl
    Thanks for the advise. It's all AC Delco sensors with NGK plugs on a stock tune. It was running rich before and after the sensors were replaced so I don't think it's related to one of the sensors. I didn't notice any exhaust leaks but I'm going to pull the front P log and inspect it for any cracks since those were a bit notorious for cracking at the welds.
  5. #5 Re: Running Rich 04 GTP
    hangover park IL
    dont bother, just light s cigarete and wave it around under it and look for the smoke to blow around near a leak.
    if it was a leak the pcm would be reading it as lean, and it would be + 20 LTFT comanded
    im going to guess the PCM was tuned and the car demodded.
    flip the PCM over and see if the large paper OEM labels are still there (size of 2 packs of smokes, 100's next to each other) or if its just a small (probably blank by now) zzp/intense label (buisness card sized)
    even if its still the factory tag, it may be tuned just not a store bought canned tune.
  6. #6 Re: Running Rich 04 GTP
    Jun 2021
    Unplug each fuel injector and write down what the fuel trims are after idling for 5 min after unplugging each injector. Only thing that can cause our cars to run rich are bad maf or bad injector. Only other issue I can think of could be a bad 02 that isn't completely dead but it's reading improperly.. a simple check for the o2 would be to cause a rich or lean condition and see if the o2 responds to it . Pull the vac line off the brake booster and see if the trims drop. If they do then you can most likely trust the o2.. I can't hear the motor run so it's hard to diagnose but only other possiblity I can think of is a cyl not firing.. but that would most likely give a misfire code and you didn't mention one so if it's running rich without a misfire code then it would have to be a bad maf, bad injector, or bad o2.. and if your not using acdelco parts I wouldn't trust it... I would start with the maf and if it's not a acdelco maf then replace it just for that reason.. after market maf and o2 sensors do not work well on our cars.. stick with acdelco parts or you will end up wishing you did
  1. 2000 GTP Running Rich
    By addeible in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2013, 12:27 PM
  2. Running too rich?
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2013, 09:43 AM
  3. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
