Thread: Who's Done Homemade Fuel Rails (With an fittings)
Results 1 to 20 of 33
  1. #1 Who's Done Homemade Fuel Rails (With an fittings)
    Quebec
    I know that there was a thread on clupgp about who has made their own modd'd fuel rails. I’ve noticed that there seem to be more fabricators over here and wanted to see if/what the creations over here look like & to see what ideas are floating around.
    I’m getting ready to make my own set and was hoping/looking for more pics of different setups before I start making mine, I’ve got a pretty good idea of what I’m going to do for the cross over line, but I’m not sure exactly what to do with the feed & return lines (mainly concerned about the angles & the best way to route those lines.
    I’m only interested in setups that use an fittings & braided line. I’d eventually like to replace all the nylon line with 6an braided line
    For anyone that’s done this I’d love to see a list of what you used, I don’t want to order too much line or too many fittings (not cheap).
    2000 GTP - Getting Faster All The Time
  2. #2 Re: Who's Done Homemade Fuel Rails (With an fittings)
    I live here. UR LOSN's Avatar
    Rockford, IL
    nope, cant say that I have seen any....
    would be cool to see!
  3. #3 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Bastard Reptile's Avatar
    Kansas City, MO
    I had bought a L32 fuel rail a few years ago in an attempt to make some, but my laziness keeps me from taking on the task.
  4. #4 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Oklahoma
    It is on my project list actually. Ive been collecting part numbers and so forth and I saved the information from cgp as well.
    If you use stock rails, I think the only difference would be that you would need -AN quick connect fittings. If you use Aftermarket rails, they typically already have the -AN fittings on them so you could buy the ss braided line and hose fittings and hook up.
    What I want to do, however is go all the way back to the tank. So my cost is going to be in the ss braided line. I want to plug directly to the fuel pump. If Im going to do it, Im going to go all out and do it.
    If I sticky this thread, are their people here that could help put together all the parts needed? Part numbers, where to buy, costs, all that good stuff? If so, if we could get everyone to pitch in I'll sticky this and we can come up with all that would be needed to do this with stock rails, aftermarket rails, all the way to the tank and pump and also for those that just want to get rid of the plastic lines in the engine bay.
    What do you all say, willing to help out and get this done?
  5. #5 Re: Who's Done Homemade Fuel Rails (With an fittings)
    SE Level Member GTP SE's Avatar
    Ankeny, IA
    My brother has a set up on his GTX that the previous owner made. I personally don't like it, but will try to see if I have any Pics.
    2001 GTP Special Edition
    |ZZP PCM|Headers|Ported LIM and blower|3.2 / 3.4 pulley|1.9's|MSD wires|Drilled 180* T stat|3" ZZP Catback l
  6. #6 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Ankeny, IA
    Pics up no AN fitting though.
  7. #7 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Rockford, IL
    are those "AN"..or just NPT?
    Scotty the part numbers I gave you for the quick disconnect fittings/to AN -6 wold work for the pump in back....
  8. #8 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Ankeny, IA
    NO on the AN fittings
  9. #9 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Oklahoma
    Quote Originally Posted by UR LOSN View Post
    Yeah, thats good to know. So we may have to list those up.
    As for the GTX, Ive seen that set up before I believe and Im not terribly crazy about it myself. I think those are just plain compression fittings and while it may work, I would be concerned about using them in an automotive application with all the vibrations and so forth.
  10. #10 Re: Who's Done Homemade Fuel Rails (With an fittings)
    GTP Level Member David99GTP's Avatar
    Florida
    I ordered a set of PRJs and they were pricy. I'd like to see more home made sets. DIY would save a bit of cash!
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  11. #11 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Oklahoma
    Did you get the latest version? They supposedly improved the design. How much did they cost you?
  12. #12 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Florida
    464 including shipping from 3800 performance. I was debating between them and ZZPs and everyone said go with the PRJs. Plus the red matches my color theme LOL
    1999 GTP
  13. #13 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Oklahoma
    I dont like how ZZP's rails match. I figure if you are going to design a set of rails from the ground up, it seems to me you would use the stock mounting locations, instead they use the valve cover bolts to hold down the rails and with the rubber bushings the valve covers use I just cant see that being the ideal thing to do.
    However, the one thing I dont like about the PRJ rails, as silly as it may see is that they are red. I want some silver or clear. I suppose I could paint them but I figure if I pay over $450 for a set of rails I should be able to get them in the color I want.
  14. #14 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Florida
    Yeah I agree. If my car wasnt a red and black theme I wouldnt have bought them. My engine bay is black with red accessories so I lucked out they went with red. According to PRJ they have only sold 150 of the new sets to date. So I am sure with sales color options will eventually be available.
    1999 GTP
  15. #15 Re: Who's Done Homemade Fuel Rails (With an fittings)
    SE Level Member BlackGS's Avatar
    Central Jersey
    The rubber bushing stock VC bolts are removed for different bolts when installing the ZZP rails.
    I've had the ZZP rails for a while now, and they work great, but I did have some early problems. They initially leaked at the input line connection and two of the injectors. I had to get a new connector, realign the rails and add some extra grease before they sealed tight. That was 6 months ago and they haven't leaked since. Then the FP gauge died, and I had to buy a replacement from Summit. For how much rails cost, they should be without these kinds of problems. I've had homemade rails on my truck for nearly 10 years without ever having a problem.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  16. #16 Re: Who's Done Homemade Fuel Rails (With an fittings)
    hangover park IL, in the garage working on one of 12 3800's
    this was a jury-rig we did to get the whippledRiv running with the aeromotive FPR before i was done with the logs, if i'd spent a little more time i coulda made em look better but this arangment would work perfectly well with standard 45* SAE flares or weld-on/compression type an fittings.
    and yes the hoseclamps held fine i did my usual grooving trick with my tubing cutter drove it like that for 10 days lol
  17. #17 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Oklahoma
    I hope so, I would love to have a set.
  18. #18 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Rockford, IL
    Well, you could design your own........
  19. #19 Re: Who's Done Homemade Fuel Rails (With an fittings)
    Oklahoma
    I wish it were that easy or I would have already went there.
  20. #20 Re: Who's Done Homemade Fuel Rails (With an fittings)
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    get some garden hose, and a few adapters, and off you go!
  1. Polishing stock fuel rails [*]
    By chitownchevy in forum How To Write-Ups/Tech Tips
    Last Post: 06-22-2009, 01:52 PM
  2. Roof rails
    By JashGTP in forum Visual/Body Modifications
    Last Post: 01-13-2008, 03:15 AM
