Thread: boost reference line for meth injection controller
Results 1 to 6 of 6
  1. #1 boost reference line for meth injection controller
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    I have a 2004 gtp and was wondering where would be a good spot to tee into for the boost reference line to my aem meth kit?
  2. #2 Re: boost reference line for meth injection controller
    i put a t in the line right before the map sensor, then into the car via the trans shift cable hole to my glove box where the controller lived.
  3. #3 Re: boost reference line for meth injection controller
    Sep 2018
    NC
    at the soft rubber that connects to the maf or in between the hard plastic line?
  4. #4 Re: boost reference line for meth injection controller
    map, not maf...my hard line were long gone, so i had normal vac lines re ran everywhere. so basically between the t under the snout, and the map. you can cut the hard line and use two pieces of vac line to put the t in with.
  5. #5 Re: boost reference line for meth injection controller
    Oct 2014
    portland oregon
    I put mine in The same place as Scotty with out knowing. Worked out great
    Sent from my SM-G981V using Tapatalk
  6. #6 Re: boost reference line for meth injection controller
    Sep 2018
    NC
    yes I meant map. i just replaced the hard line... oh well
  1. Meth injection question
    By hockeybawler in forum General Tech Discussion
    Last Post: 09-08-2015, 04:01 PM
  2. WTB: Meth Injection KIT
    By fri3dchick3n in forum Wanted To Buy - Parts
    Last Post: 03-01-2013, 04:48 PM
  3. Meth Injection Kit
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2012, 12:41 AM
  4. DIY Meth injection ?'s
    By TEK310 in forum General Tech Discussion
    Last Post: 06-23-2012, 01:23 PM
