Thread: Which tensioner assemblies & idler pulley to buy?
Results 1 to 4 of 4
  1. #1 Which tensioner assemblies & idler pulley to buy?
    Feb 2016
    Iowa
    Chats
    Greetings all. Happy New Year.
    The idler pulley on my '02 GTP broke today, so I picked up a new pulley and both belts.
    I am thinking about replacing both the supercharger and accessory tensioner assemblies as well. I do not have a service manual and cannot tell is there is an accessory belt idler pulley, but if I can see one tomorrow in the daylight, I will replace it also.
    But first, did I purchase the correct supercharger idler pulley? I bought the grooved Gates p/n # 38009. The remains of the pulley that broke is no where to be seen, so I don't know if I need the grooved or non-grooved part. Did I get the right one?
    As for the tensioner assemblies, it looks like Gates p/n # 38365 for the supercharger and p/n # 38271 for the accessory belt.
    The installation of the supercharger assembly looks pretty straight forward, other than maybe needing a special tool.
    The accessory belt assembly looks a little more troublesome. From the pics it looks like it may serve more than one purpose. If so, what else does it do? What are the two 90 degree fittings for? Wondering if I may be opening up a can of worms here. You know, working in my driveway in the winter.
    Is there an idler pulley for the accessory belt?
    And do I need any special tools?
    Any suggestions or tips will be greatly appreciated.
    Thank you,
    Scott
    Which tensioner assemblies & idler pulley to buy? Attached Images
  2. #2 Re: Which tensioner assemblies & idler pulley to buy?
    Feb 2016
    Iowa
    Chats
    Update: I found the belt routing diagram on the radiator support and it looks like there is not an idler pulley for the accessory belt. One question answered.
    However there are two idler pulleys for the supercharger belt. The one that is broken is the small pulley closest to the front of the car. The other idler pulley and the tensioner pulley both spin relatively freely. No wobble or grinding sound while spinning with my hand.
    The bearing that remains on the shaft of the smaller idler pulley does not spin at all - like it is frozen. Think that's why the pulley broke?
    I had no idea there was a problem with that pulley. The pulley's bearing actually. No clues that there was something wrong at all until it gave up the ghost.
    I'll bet it is going to be a pita getting that bearing off the shaft.
  3. #3 Re: Which tensioner assemblies & idler pulley to buy?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Chats
    25
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. Thanks 330Scott thanked for this post
    Likes 330Scott liked this post
  5. #4 Re: Which tensioner assemblies & idler pulley to buy?
    Feb 2016
    Iowa
    Chats
    Thanks for the pic, mguzzo. It confirmed that the grooved pulley was in fact the pulley that I needed.
    I just now replaced the pulley and belts and will call it good for now. That tensioner assembly looks to be a bit of a bear to replace. Never seen anything like it.
    Anyway the job is done.
    Thanks again,
    Scott
  1. Grooved Idler Pulley
    By valente in forum General Tech Discussion
    Last Post: 04-08-2014, 02:05 PM
  2. 3.5 idler pulley
    By jc71corvette2 in forum Introductions/Noob Questions
    Last Post: 02-25-2014, 03:02 PM
  3. 98 GTP supercharger idler and tensioner pulley help
    By BillA in forum General Grand Prix Discussion
    Last Post: 09-20-2012, 09:25 PM
  4. Idler&tensioner pulley help
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-15-2010, 10:36 AM
