Thread: k&N Air intake
Results 1 to 5 of 5
  1. #1 k&N Air intake
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    does anyone run 1 of these . when i went to my local parts store to see if they can order 1 they dont make a model for the gtp but i see them on zzp and 3800 performances websites . i am really sort of stuck on which way to go because i would like to get the most horsepower out of my money and i will probably gut my stock air box and put a aem dryflow filter in it first then move on to a air intake system when i have the money for it . what do you guy recommend ? will there be a big or little difference from a gutted air box to a intake system ??
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: k&N Air intake
    Saraland Alabama
    I just have a generic K&N cone on mine
  3. #3 Re: k&N Air intake
    SE Level Member snow99dohc's Avatar
    Rugby ND The Center of Nor. Amer.
    What most people do is run a custom FWI with a k/n cone.
    I run a intake based off of StreetWolf's howto.
    k&N Air intake Attached Images
    2003 Pontiac Gran Prix GTP-Thrasher CAI, 180 degree t-stat, AL 104's, ZZP/PT Pcm, ZZP Stg 1 HV TB, ZZP headers, 3'' custom catback, magnaflow mufflers, 3.4''
  4. #4 Re: k&N Air intake
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    The K&N has downside of an open cone combined with the addtional length of a FWI. Not the best combination. Either go FWI or a real CAI.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: k&N Air intake
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    K&N intake for our cars is a POS.
  1. Make A 4" Fenderwell Intake (FWI)[*]
    By Street Wolf in forum How To Write-Ups/Tech Tips
    Last Post: 05-17-2019, 05:23 PM
  2. L26 intake v.s. Blocked off supercharger
    By Andrew_99GTP in forum Turbo
    Last Post: 11-03-2008, 09:05 AM
  3. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
  4. best air intake
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2008, 11:47 PM
