Thread: Trying to calculate hp from my mass airflow rate of 32.54 lb/min
Results 1 to 2 of 2
  1. #1 Trying to calculate hp from my mass airflow rate of 32.54 lb/min
    Nov 2020
    Baltimore
    Chats
    My MAF Airflow rate with the mods listed below : 32.54 lb/min on a 60 degree day with 56% humidity, under hood inlet air averaging between 82-85 degrees at the MAF. Seeing 2.3 KR from 5700rpm to 6000rpm, with a slight blip of 4.0 from 5500-5700 initially. Any idea what my horsepower is based on that air flow number?
    I’m thinking somewhere around 290 crank hp. I -sort of- logged the data in a screenshot from my dash command app I use on iPhone (all extended PID’s were purchased). The screenshot I can post after this won’t make any sense unless you completely 100% understand the layout of the Dash Commander data grid. I plan to get it dynoed but was just curious how accurate maf air flow to hp conversions are. Still on the stock 3.8 supercharger pulley, also this of course is a Gen V supercharger. Car has 198k on the engine and transmission. Thanks in advance and the current setup of the car as well as the screenshot, are shown below :
    2007 Pontiac Grand Prix GT Supercharged 4AT (Bolt Ons, Mildly Gutted, “First Draft” Edition)
    Changes to the car :
    4 Inch Inlet Intake Filter
    Autolite XP104 Iridium (-not- the normal copper 104's) plugs gapped to 0.050
    ZZP Alternator Power Cable
    ZZP 180 Degree Thermostat
    ZZP Polyurethane Dog Bone Bushings
    ZZP Polyurethane Upper Motor Mounts
    ZZP Aluminum Transmission Pan
    3 Inch Collector BHR Stainless Steel/Titanium Wrapped Headers
    3 Inch BHR Catless Downpipe
    3 Inch Catback w/ Cherry Bomb Glasspacks
    EGR Bypass
    TransGo Shift Kit
    93 Tuned by Daniel Smuts
  2. #2 Re: Trying to calculate hp from my mass airflow rate of 32.54 lb/min
    May 2008
    Schuyler, NE
    Chats
    265
    General rule of thumb to figure crank hp is multiply your lb/min by 10. That is of course a very loose figure, so don't get too caught up on it.
  3. Thanks LouF thanked for this post
    Likes LouF liked this post
  1. GM 85mm LS6 LQ4 MAF Mass Airflow kit
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2017, 06:08 PM
  2. Mass Airflow Sensor question
    By Dean10e in forum General Tech Discussion
    Last Post: 11-11-2011, 07:31 PM
  3. mass airflow sensor issue,
    By will54768 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2010, 01:19 AM
  4. Mass airflow sensor troubles!
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 03:33 PM
  5. Where is mass airflow sensor on 3800?
    Last Post: 11-18-2008, 11:10 PM
