#1
Radiator Fans not working
I have a 2000 Grand Prix GTP. The radiator fans won’t turn on unless I unplug the coolant temp sensor. I’ve checked the relays and fuses and wiring and it’s all good. The coolant temp sensor works, the dash will show the temp, does that mean the sensor is working or could changing the sensor still fix the fans? At this point it’s gotta be either the sensor or the PCM. What is the most likely scenario?
#2
Re: Radiator Fans not working
11-27-2020
change the temp sensor. its a two part deal, one reading goes to the dash, the other to the pcm. if the pcm see's no signal it wont turn the fans on.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
I will give that a try and let you know if it works. Thanks!
#4
11-28-2020
theres also a short harness temp sensor to main harness, it fails too. so if you see cracked insulation or bare wire, change that as well.
#5
Yeah I thought about that but I couldn’t find the harness at the junk yard anywhere. Changing the sensor fixed the problem though. Thanks!
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
