Thread: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
Results 1 to 13 of 13
  1. #1 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Feb 2010
    Tampa
    I have a 2002 Pontiac grand prix 3.8 supercharged, that stalls out in the middle of driving after about 15 minutes. The engine will completely turn off and come to a stop. The air-conditioning, radio and everything else will still work. There is no check engine light. No codes. I replace the cam sensor, the crankshaft sensor, the ignition control module, and had my fuel line pressure tested. I will let the car sit for a while when I bring it to the shop and it starts right back up. But after driving it for a few days it stalls out again and I'm stranded on the side of the road. I brought it to the shop many different times already and there is no issue that is showing. When I try to crank the car it acts like it wants to start but will not turn over.
  2. #2 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Dec 2008
    Lawndale, CA
    Maybe an IAC valve.
  3. #3 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    crank sensor will do this, hardly ever sets a code either.
  4. #4 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Feb 2010
    Tampa
    I already replaced th crank sensor
  5. #5 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    id you tq its bolt right? was it aftermarket?
    the little harness there goes bad too, icm to cam and crank sensor.s.
  6. #6 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Feb 2010
    Tampa
    My mechanic put on my crankshaft sensor so I think he would check the harness but I will call and make sure.
  7. #7 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Quote Originally Posted by GoBstoPpEr View Post
    find out what brand he used, the 3800 pretty much hates all aftermarket sensors. delco should be the first choice.
  8. #8 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Feb 2010
    Tampa
    It is the I purchase the part myself.
  9. #9 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Feb 2010
    Tampa
    It is delve I purchased the part myself
  10. #10 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Feb 2010
    Tampa
    Delco
  11. #11 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Sep 2020
    Wyoming
    Dumb question here, have you tried replacing your fuel pump/fuel filter? Maybe check your sparkies/wires too, just to err on the side of caution?
    Also, when it cuts out, do you ever smell fuel?
  12. #12 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    Nov 2016
    Fremont CA
    Hi you said you replaced the ignition module have you replaced the coil pack towers there should be six of them one for each cylinder you might want to replace your coil pack towers that might be the issue? I would also do research on intermittent coil pack power related issues but you might want to try that that's off the top of my head I don't know your situation but I thought I'd offer that good luck!
  13. #13 Re: 2002 Pontiac grand prix 3.8 supercharged stalls and wont start
    St. Louis
    No, there are 3 coil packs, which fire 2 cylinders each. These cars don't have COP from the factory.
  1. pontiac grand prix gt wont start
    By snoel268 in forum Introductions/Noob Questions
    Last Post: 03-08-2016, 07:01 PM
  2. 97 pontiac grand prix gt wont start
    By manny in forum Introductions/Noob Questions
    Last Post: 09-26-2014, 04:58 PM
  3. 1998 pontiac grand prix gt wont start
    By jkrizan in forum Introductions/Noob Questions
    Last Post: 01-09-2013, 04:17 PM
  4. 97 grand prix gtp 3800 supercharged wont start
    By angie8907 in forum Introductions/Noob Questions
    Last Post: 11-05-2012, 05:18 PM
  5. 1995 pontiac grand prix turning over but wont start.. help!
    By kdf401 in forum General Tech Discussion
    Last Post: 10-12-2012, 07:09 PM
