Thread: Valve spring question
Results 1 to 2 of 2
  1. #1 Valve spring question
    Sep 2020
    mn
    Chats
    Hi, im installing a xp hot cam with everything zzp reccomends the issue is they are out of stock of the 136# springs althrough jegs may have the ones i think zzp sells -
    COMP Cams CONICAL VALVESPRINGS .650/.920D 438LB R
    Part Number: 249-7228-12 Rate: 438 lbs
    Inner Diameter: .650'' Top, .920'' Bottom
    Outer Diameter: 1.020'' Top, 1.290'' Bottom
    Seat Load: 136 lbs at 1.800''
    Open Load: 412 lbs at 1.170''
    Coil Bind Height: 1.125''
    12/pkg
    The thing that is throwing me off is i thought the zzp 136's were beehive springs and Jegs are conical springs also im not sure if the Jegs springs are meant for an LS if so i would thing they would work for sure.
  2. #2 Re: Valve spring question
    May 2008
    Schuyler, NE
    Chats
    265
    I would go for these instead. I'm not a fan of comp springs. Too many people have lost engines due to them.
    PAC-1218 LS1 HP Ovate Wire Beehive - LS Engine Products - General Motors - Applications | PAC Racing Springs
  1. How do you end up with a shorter valve spring ?
    By CrazyGuy03 in forum General Tech Discussion
    Last Post: 05-16-2015, 06:44 PM
  2. Valve spring question..
    By Cali boi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2014, 09:26 PM
  3. Question on valve spring
    By BlackGT97 in forum General Tech Discussion
    Last Post: 01-14-2013, 10:17 PM
  4. valve spring seal
    By blazinzuk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2010, 07:39 PM
  5. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
